02-23-2011, 07:38 PM | #1 |
Should I buy? What to match?
I have a good line on the following from someone I know and mostly trust(trust him more than people I do not know) I have him at just under $1500 for the following:
Kingpin chevy front 60-professionally assembled. 5.38:1 yukon gears, highsteer, 1 ton tie rod, disk brakes, detroit locker Corp. 14 bolt rear - professionally assembled. 5.38:1 yukon gears, drum brakes, detroit locker all stock chevy brackets intact. I am not sure what to match with in the rear end? I am seeing several dana 70s rear around a couple dana 60 rears and 14 bolt as my options. Which should I go for as a rear end? Also since it is a 5.38 front will i have to change out my carrier? Thanks all.
Confidence is the feeling we have before we fully comprehend the situation |
02-23-2011, 08:59 PM | #2 |
Re: Should I buy? What to match?
What exactly are you asking? If it comes with a 14 bolt rear why not use that. It is better then a dana 60 rear..
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
02-23-2011, 09:05 PM | #3 |
02-23-2011, 09:06 PM | #4 |
Pay him NOW! You yankees have some sweet deals down there.
Custom Vehicle, Custom Problems. Last edited by LANDC; 02-23-2011 at 09:08 PM. |
02-24-2011, 05:54 AM | #5 |
The 14 bolt is definitely an awsome rear end. Look at any serious Rock Crawler and out of 1000 you'll probably find 995 14 bolts. They're indestructable.
1968 K10/30 Frame Off Project "Overkill" My 5 year, $30,000.00 toy |
02-24-2011, 09:49 AM | #6 |
Sorry all I did not realize that it posted the set. The rear has sold. he wanted 2500 for set and is now asking 1500 for front. I am thinking about offering him 1200 and going from there... I have a line on a 14 bolt rear for $100 complete. Just need to research a bit more and make sure it is the right one.
02-24-2011, 05:27 PM | #7 |
I've ran the 14bolt in five of my trucks in the past and never had a single problem with any of them. The one thats under my 72 has been there for almost thirty years, the last 20 with a Detroit locker and its just starting to need a rebuild. Just my two cents, hope it helps.
Also to answer your question, if you find a 4.10 or 4.56 housing you can put the 5.38's in it. I believe they wont fit in the 3.73 highway geared housings but I could be wrong.
Professional hot glue and pop cycle stick engineer. 72 K/20 soon to be C/10, 454, Th400, 9” rear. 01 GMC 2500HD 8.1, Allison, daily/towpig gas guzzler. 78 Bahner 19’ jet boat, 460 Furd turd. Last edited by modblacksmith; 02-24-2011 at 05:32 PM. |
02-25-2011, 12:12 AM | #8 |
Chevys Kick A$$
Yea there are an awesome the 14bolts that's for sure! It just depends on how much money that you want to spend. That is not a horrible price but I have seen better lol.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
