Old 02-23-2011, 09:28 PM   #1
chevyrestoguy
chevyrestoguy's Avatar
Need help in settling a "bet"
Big betting stakes here......Breakfast at the place of my choice.
Here's what it's all about:
My truck is a 3/4 ton, manual trans, and the e-brake is just to the right and behind the shifter. My buddy SWEARS that only the 1-ton trucks had the e-brake handles in that spot. I say no. By the VIN#, my truck decodes as a 3/4 ton.
OK experts, the question needs to be answered. I'm getting hungry.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 02-23-2011, 09:41 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: Need help in settling a "bet"
Not an expert, but the 3/4's I've seen have the brake as you describe. I think you have breakfast comin' soon!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-23-2011, 10:39 PM   #3
mikie 1954
I saw one like that on this board right after I joind, seams that the person that owned it said that it was stock on 4 wheel drives. I think he was from Canada, maybe he will see this and coment.
mikie 1954 is offline   Reply With Quote
Old 02-24-2011, 01:28 AM   #4
63 Spud
63 Spud's Avatar
Here's a build started on a '63 C20 with the hand ebrake. 6th picture down shows the hand brake.
http://67-72chevytrucks.com/vboard/s...d.php?t=400426
63 Spud is offline   Reply With Quote
Old 02-24-2011, 01:55 AM   #5
Captainfab
60-66 Nut
All the C20's I've seen around here have the e-brake lever under the dash like the C10's. I haden't seen a C20 with the e-brake lever to the right of the shifter until I joined this forum. I had previously thought that was only C30's. I really don't know what determines where the lever is located.
Old 02-24-2011, 09:10 AM   #6
duallyjams
duallyjams's Avatar
Wonder if this is like the fawn fire wall trucks ( production plant )because I have even seen 1/2 ton with a e=brake on the floor to the right of a 4 speed truck on the 1960 to 63 model.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-24-2011, 09:47 AM   #7
chevykid65
chevykid65's Avatar
i know one around here thats a 60 or 61 3/4 2wd and it has the e brake on the floor next to the shifter. as far as i can tell its all original except for the grill and hood
chevykid65 is offline   Reply With Quote
Old 02-24-2011, 10:01 AM   #8
Mechanic77
My '64 C20 originally had a 292 with a 4 speed and it had the e-brake next to the shifter with the e-brake assembly mounted on the back of the transmission....maybe only the trucks with the eaton rearend were done that way? I think someone owes you breakfast
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627
Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948
Mechanic77 is offline   Reply With Quote
Old 02-24-2011, 11:01 AM   #9
ChevySixty6
ChevySixty6's Avatar
The blue one in my avatar, which i've since sold, was an orig. '66 C20 with
the granny low 4 spd. It had the e-brake under the dash like a C10.
Members i've met: LiLRed66
ChevySixty6 is offline   Reply With Quote
Old 02-24-2011, 11:04 AM   #10
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
at the local yard where there 50+ 60-66's about a 1/4 of them are 3/4 ton, 2 have the trans brake the rest have the under dash brake
Old 02-24-2011, 11:06 AM   #11
SFTorange
SFTorange's Avatar
For what it's worth, my '66 C20 has the standard e-brake under the dash, and it came with an Eaton rear.
Interesting topic. I've never seen the e-brake through the floor.
SFTorange is offline   Reply With Quote
Old 02-24-2011, 09:33 PM   #12
factorystock
factorystock's Avatar
Cable actuated parking brakes were new on 4spd C 20's in 1965. 1960 thru 1964 C 20 4spds used the parking brake drum.
factorystock is offline   Reply With Quote
Old 02-25-2011, 02:22 AM   #13
Captainfab
60-66 Nut
Thanks for clarifying that. Now we know.....
