01-17-2010, 04:49 PM | #1 |
door ajustments
dos any body know if you can adjust the hidges on a 64 c10? or do i have to replace the hinge pin, what to do ect. thanks for the help. the doors seem to sag, and you have to pull the door up to close it all the way.
01-17-2010, 06:20 PM | #2 | |
Senior Enthusiast
Re: door ajustments
Door adjustment may be accomplished at two places; at the hinge straps to door panel and at the hinge cage to pillar. Before adjustment is made on any door, however, the striker plate and wedge should be loosened or removed. The door can be moved fore, aft, up and down at the hinge pillar and the door can be moved in and out at the hinge to door panel. Move door as required and tighten bolts to 20-25 ft. lbs. The door should have a normal clearance of 5/32” around the entire outer lip of door except at the bottom where it should be ¼” from the door sill. The door should be adjusted in the opening so the edge of the door across the top and also at the lock side is parallel with the body opening as nearly as possible. |
01-17-2010, 07:53 PM | #3 |
Re: door ajustments
hey there markebol! thanks for the fast response. will get a set of hidge repair kit for each door just in case. will check out adjustments when i get the " bad bowtie" back out of hibernation in the spring. thanks again, have fun, and bring on spring!
01-18-2010, 01:47 PM | #4 |
Wide Eyed User
Re: door ajustments
I am having a heck of a time lining up my doors, I am thinking of just upgrading to bear claws and be done with it... I would rather keep the stock, but....
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ) Pics: http://67-72chevytrucks.com/vboard/s...d.php?t=393441 |
02-23-2011, 11:04 AM | #5 |
Junior Member
Re: door ajustments
I am ready to align mine and am always a bit confused. I understand which are for in/out and up/down/forward/back, but all I read seems to indicate to only loosen one hinge at a time and move it. It would seem both would have to be loose for the door to move.
What am I missing?
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! |
02-25-2011, 10:53 AM | #6 |
Junior Member
Re: door ajustments
Anybody that can help me understand this?
02-25-2011, 01:09 PM | #7 |
Re: door ajustments
Both sets do not have to be loose. But they shouldnt be really tight. Work with one hinge at a time. I only put 2 bolts in on both halves of the hinge. I have one bolt snug and one less snug. Which allows for some movement.Its just trial an error until the door is centered. Everybody gets excited about loosening hinges. Just loosen the bolts enough to move it around and dont let it fall into the body and chip the paint. 1/4 inch gap at bottom and 1/8 to 5/32 around the sides and top. Or whatever looks centered. I have found several trucks to have a tight gap at the point where the driprail is at the edge of the windshield(64-66). Thats all i know so far.
02-25-2011, 02:31 PM | #8 |
Re: door ajustments
thanks for posting this information. I needed it.
