Old 01-26-2011, 08:22 PM   #1
nikwho
nikwho's Avatar
disc brakes for my '79 8.5" 10 bolt rear?
This topic is now an FAQ-"Disc Brakes- 8.5" 10 bolt axle (70-81 Camaro or 98-04 S10-Blazer )"
I have a '79 8.5" 10 bolt rear axle on the '59 from a camaro. Is there a vehicle that i can nab the rear disc brakes off of to convert it? Im looking for an economical way to convert to disc brakes in the rear. Any other thoughts?
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 01-26-2011, 09:03 PM   #2
cap n crunch
cap n crunch's Avatar
Re: disc brakes for my '79 8.5" 10 bolt rear?
Speedway metric caliper brackets $10 bucks, 4x4 S-10 Rear rotors around $50 each new, metric calipers around $30 a piece new............
ONE PIECE AT A TIME
http://67-72chevytrucks.com/vboard/s...d.php?t=442320 My Build Thread
cap n crunch is offline   Reply With Quote
Old 01-26-2011, 09:52 PM   #3
oldschool53_BBC
oldschool53_BBC's Avatar
agree
1953 BBC 3100
427 T-400 12 Bolt
Al
oldschool53_BBC is offline   Reply With Quote
Old 01-27-2011, 09:34 AM   #4
skip99
skip99's Avatar
I've done a couple disc conversions on camaros, I got my stuff from Right Stuff in Columbus Oh. 18004052000, I actually call them for tech support and make sure I get the right part numbers. then I have a friend who is a vendor of theirs order for me, he gets a big discount.. I know, it's screwy... right stuff is right down the road from me, but it's cheaper for my friend in another state to order. I just go pick it up. but they do protect their vendors. anyway, you can get calipers, brackets, spacers, lines, ebrake cables, rotors, flex hoses and the correct master, for around 400..
ask for Todd.. at Right stuff
I would order through Coast2coast camaro..248-933-0440 Richard..
skip99 is offline   Reply With Quote
Old 01-27-2011, 10:03 AM   #5
Trucknut57
Trucknut57's Avatar
I went to my local LKQ and picked up the parts I needed from a 98 - 04 S10 Blazer.
Below is a complete list of the parts you will need to do the conversion. Some parts you may already have but if not, its listed. Hope its helpful.
A comprehensive list of what needs to be done to go from factory rear drum on a
70-81 Camaro to 98-04 S10-Blazer rear disc.
Parts you will need:
1 - Driver side 4WD backing plate, e-brake assembly (GM PN-15064302)
1 - Passenger side 2WD backing plate, e-brake assembly (GM PN-15773309)
8 - 3/8 bolts, lock washers and nuts to mount backing plate to rear housing
3/8 washers to shim the backing plate for perfect fitment of the caliper to rotor
(2 each bolt in my case)
2 - Driver side 4WD caliper, or passenger side 2WD caliper, mix & match
(Loaded kit w/ brackets & pads Cardone PN-164712) (Loaded kit w/ brackets &
pads NAPA PN-TS 1422228)
2 - Caliper brackets - if needed
1 - Brake pad set - if needed (HAWK HB119F-594)
4 - caliper bracket bolts (GM PN-15726460)
2 - banjo bolts (GM PN-10286122)
2 - 2WD Blazer rotors (NAPA 4886725) (Powerslot 8638PSL & 8638PSR)
1 - Master cylinder (80 disc/disc T/A, 79 disc/disc Vette, 70 manual disc/disc
Vette all work)
2 - Brake hoses (you can use stock Blazer hoses or any braided stainless ones with
a 10mm banjo fitting)
1 - Prop valve (stock 80 T/A works, I used a Summit adjustable)
New style brake cable (I used the Blazer cables, but Lokar universal would be
less work)
Brake fluid, gear oil, axle seals
Somehow, the idiots survive despite their best efforts to kill themselves.
- dcozzi
Trucknut57 is offline   Reply With Quote
Old 01-27-2011, 12:05 PM   #6
nikwho
nikwho's Avatar
Thanks guys! I always find all of the answers here!!!
'68 GMC - BBC/TH400
Old 01-27-2011, 03:35 PM   #7
Houston54
One thing to keep in mind if you do change over to rear discs is your master cylinder and/or proportioning valve may also need to be replaced.
I considered adding discs to the 10 bolt on my 54 but the drum brakes work just fine.
Houston54 is offline   Reply With Quote
Old 01-27-2011, 04:05 PM   #8
bretcopsey
Another possible issue with GM c-clip axles is pad knock back. The end play in the axles can cause the disc to kick into the pads, pushing the caliper piston back into the bore. The end result is a "soft pedal" feel the next time you apply the brakes.
Some guys go the extra mile and shim the ends of the axles inside the carrier. It may be overkill, but something to at least keep in mind if you experience the soft pedal issue....
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 01-27-2011, 07:26 PM   #9
nikwho
nikwho's Avatar
wow. interesting! I think that I may just put it together with the drums and wait to see if it goes well. But if I end up needing to buy new drums, shoes and hardware kit, i'd rather spend the money for the discs. C clip eliminators maybe? also, does this make it that you dont have an e brake?
'68 GMC - BBC/TH400
Old 01-28-2011, 03:02 AM   #10
sweet70beast
sweet70beast's Avatar
I used Firebird rotors too but I used 79 Cad backing plates, e-brake calipers, master and prop valve. Used the little push rod from the cad in my 70 Nova vacuum booster. Everything bolted right on.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 02-24-2011, 09:25 PM   #11
hammerdog57
hammerdog57's Avatar
How did they shim end of axles inside carrier? I am installing disc brakes on my camaro rearend and have to much axle end play on one axle. Drivers side end play .008 Passenger side .028
hammerdog57 is offline   Reply With Quote
Old 02-25-2011, 01:29 PM   #12
bretcopsey
Just read on the 'net-I have not done this myself...
http://www.camaros.net/forums/showth...ght=knock+back
"Your problem might be excessive end play in the axles. The same problem happens with JL8 conversions.
Try shimming behind the C clips with a spacer. I've heard a valve spring spacer with a little filing will work well.
Get the end play close to zero. If you go too tight it may affect the positraction function."
"Yes, put the spacer between the side gear and the C clip. You will need around .015" to .030" thick shims.
There used to be thicker C clips to do this but I don't think they are available anymore. If you go too thick you may prevent release of the positraction.
Non posi rears are looser than the posi type, which would knock the caliper pistons back even farther."
My 51 project
Old 02-25-2011, 03:20 PM   #13
tmoble
Trucknut57, can you answer that about having a park brake with the setup you described?
Also, can you say why a mix of 4WD and 2WD parts are needed? I don't get that.
tmoble is offline   Reply With Quote
Old 02-25-2011, 09:56 PM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
