Old 02-21-2011, 02:29 PM   #1
69pickupnyc
camero gas tank
I am new to the forum, has anyone installed a camero gas tank in the rear between the frame rails. By using a camero gas tank you would be able to run the filler through the rear plate and not have to modify the bed
69pickupnyc is offline   Reply With Quote
Old 02-21-2011, 02:33 PM   #2
geezer#99
geezer#99's Avatar
Re: camero gas tank
Here's Scott's project.
http://67-72chevytrucks.com/vboard/s...=445201&page=2
geezer#99 is online now   Reply With Quote
Old 02-21-2011, 03:20 PM   #3
Bad70sbchevy
Bad70sbchevy's Avatar
Re: camero gas tank
http://67-72chevytrucks.com/vboard/s...d.php?t=423035
This thread has the whole instillation. I did it to mine for the same reason. Pretty easy to do, hardest part is just mocking up the tank to see how low you want the tank to set behind the license plate. Its a little better to have the filler neck closer to the license plate. I positioned mine back a couple inches just in case I get rear-ended it has less of a chance of spilling everywhere (still better than being in the cab). I can send you some additional specs or pics if need be.
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 02-21-2011, 05:18 PM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
Re: camero gas tank
I've never heard of a camero gas tank, must be one of those rare corvette options....
brad_man_72 is offline   Reply With Quote
Old 02-21-2011, 05:43 PM   #5
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Re: camero gas tank
Why is it so hard to spell Camaro?
I like the idea, but from those examples it hangs down too low for me.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 02-21-2011, 05:47 PM   #6
pryorstemmed
4wd Enthusiast
pryorstemmed's Avatar
Re: camero gas tank
*1972 Cheyenne Super SWB K10 Original Paint 350/350 AC (Added) Tach/Tilt
*1972 Cheyenne Super SWB K10-Buckets/Tach/Tilt/Wood Bed/Manual Throttle/Marker Lamps
*1972 Cheyenne Super Custom Camper K20 AC/Tilt/Aux Tank/Aux Battery/Wood Bed
*1970 Olds 442 W-30 M-21 4-speed
*1978 Ford F250 4x4 Ranger-Explorer-Camper Special Marti Report: 1 of 1
*1986 K30 Silverado Crew Cab 502/TH400
*2002 Silverado LT 2500 Duramax Long bed Crew Cab 4x4 107K original miles
*2022 RAM Bighorn 1500 Waldoch edition ...Daily Driver
pryorstemmed is offline   Reply With Quote
Old 02-21-2011, 08:11 PM   #7
Texasbigblock
Texasbigblock's Avatar
Re: camero gas tank
not to low for me! did mine back in 07, I may be the original! lol. I have had no problems with mine and even on a stock height truck you have to get below bumper level to see it.
-Scott-
1970 C10 shortbed 396
1969 C30 dually flatbed "Vidalia"
Texasbigblock is offline   Reply With Quote
Old 02-22-2011, 09:06 AM   #8
GCncsuHD
GCncsuHD's Avatar
Re: camero gas tank
That one looks nice, not nearly as low as the one in the link. I wish I would have known about this before hand, but I'm happy with my Boyd tank, so I'll just hack a hole in my bed somewhere Or maybe I'll weld a new neck coming out the back like that hmm, decisions.
ΜΟΛΩΝ ΛΑΒΕ
Old 02-22-2011, 12:04 PM   #9
ROBO66
ROBO66's Avatar
Re: camero gas tank
Hey, I'm in the middle of a build (67 SWB) and used a 16 gal. Mustang tank. it fit perfectly between the frame rails and cross supports. You have to do few small alterations to the bottom or the frame rails, but nothing major. It's a great fit and the center filler neck for the gas tank comes up perfect in the middle of the bed floor.
ROBO66 is offline   Reply With Quote
Old 02-22-2011, 01:09 PM   #10
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: camero gas tank
Because, when GM and Chevrolet were in the late stages of the design and early stages of pre-production mules, they were called Panther. When the name Camaro came out as the final product name, there was controversy as to whether or not it was actually a word. Someone said "Camaro" was spanish for friend. Others spelled it "Camero". It's a wonder that it didn't come out as "Camiro".....after the El Camino. Maybe is should have been the El Camiro.
I guess it all depends on how you pronounce it, in comparison to how you spell it...
Member Nr. 2770
Old 02-23-2011, 10:27 PM   #11
69pickupnyc
Re: camaro gas tank
Thank you for your quick response and spelling class. Sometimes incorrect spelling will save you money on ebay, if the person posting the item spelled the item incorrectly not that many people will bid. Lucky for me c10 is easy to spell.
Old 02-26-2011, 09:30 AM   #12
svgould
Active Member
svgould's Avatar
Re: camero gas tank
Any pictures?
1971 SWB SOLD
  • LT1 motor / 4l60E transmission
  • ECE front dropped spindles with stock height springs
  • 4" rear springs
  • Coys Wheels 18 x 8 all the way around
  • Hydratech hydroboost brake system
svgould is offline   Reply With Quote
