Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-25-2011, 06:05 PM   #1
rattleon
rattleon's Avatar
swap from power to manual steering?
I'm going to swap out my power for manual steering in my '70. I'm just wondering if it's a direct bolt in and if so what years will work? I'm thinking anything after '68, but don't know for certain and are all the ratios the same? also as an option what about using the power steering gear box and just plug it or loop the lines. Would it turn/work harder than a manual box because of gear ratio or are they the same? Thanks for any info.....Jeff
1970 c-10 short/step box morphing into street/strip
1967 RS/SS convertible Camaro
1932 Henry Ford steel 5 window coupe highboy hotrod
1931 full fendered model A sedan AV8 traditional hotrod.
1934 Ford 5 window coupe and a (pile-of-parts)
1929 Model A coupe, plus our "normal" people vehicles.
rattleon is offline   Reply With Quote
Old 02-26-2011, 01:25 AM   #2
Captainfab
60-66 Nut
Re: swap from power to manual steering?
A manual box from '67 thru mid 70's should bolt right up. I think a regular manual steering box would function better than a power box in a closed loop configuration. As far as I know all OEM truck boxes are the same ratio.
Old 02-26-2011, 11:03 AM   #3
rattleon
rattleon's Avatar
Thanks for the input Capt. I think I found a good used '72 box yesterday. I just wasn't sure if they were all the same, so I just need to go and get it out.....unfortunately we got about a foot of new snow here at my place yesterday/night which changes the days events. How about you guys up North, did you get hit by this last storm?
Old 02-26-2011, 01:14 PM   #4
CSGAS
optomistic ah-so
CSGAS's Avatar
The stock style steering arms (that bolt to the uprights) should be a different length for the two different boxes as well; any confirmations?
If so, I am sure many members who have upgraded to one-piece drop spindles or from manual-to-power steering would have the manual arms.
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
Old 02-27-2011, 12:24 AM   #5
Captainfab
60-66 Nut
Oh yeah, we got about a foot of snow, near zero temps and high winds. Was a little below zero last night. We've got another storm coming tonight/tomorrow. Supposed to get another 6-12 inches. Supposed to be a little warmer though.
Old 02-27-2011, 12:37 AM   #6
cableguy0
Power boxes dont work very well without having a pump. A manual box is a much better way to go. Im pretty sure the pitman arm is different between the two but the rest of the linkage is the same.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
