Old 02-25-2011, 02:27 PM   #1
COBALT
COBALT's Avatar
Replacing the Shocks - '99 tahoe 2wd
Simple: old shocks are blown. New Bilsteins ready to go in (yay). Do I need to compress the suspension front and back to remove the old ones and put the new ones in? I don't have a spring compressor - last time I did this was on my '69 and It was super easy (KYB's that just bolted to mounts), but the look of these strut mounts on the front make me wonder.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 02-25-2011, 02:31 PM   #2
kSStamp0182
LSX addict
kSStamp0182's Avatar
Re: Replacing the Shocks - '99 tahoe 2wd
nope just put it on jack stands and jack up the lower a arm just a little so you can get the shock out, change em. cake.
-1982 C10 SWB GMC Sierra [undergoing 6.0/4L80E swap with mild restoration]
kSStamp0182 is offline   Reply With Quote
Old 02-25-2011, 05:11 PM   #3
COBALT
COBALT's Avatar
Sweet. That's what I wanted to hear. We're down to one vehicle, and I don't wanna get everything ready to go and then have to put it all back together to go get extra tools...
Tomorrow the shocks go on. Can't wait. These Bilsteins are awesome.
Seattle, WA.
Old 02-25-2011, 05:54 PM   #4
kSStamp0182
LSX addict
lemme know how it rides! i wanna get some for my '82.
it is shocks tho right? not coilover struts? (where the strut is in the middle of the spring).
Old 02-25-2011, 06:07 PM   #5
COBALT
COBALT's Avatar
Hmmm...I'll have to look when I get home. The front are struts. They're meant to bolt up through the upper A-arm, so I'm thinking it has to go through the center of the front coils, then bold to a mount below on the lower A-arm. The upper part of the strut assembly is literally a threaded rod about 6-8" long. No mount on the top.
Seattle, WA.
Old 02-25-2011, 07:50 PM   #6
kSStamp0182
LSX addict
if it is then its a bit more involved an yes you would need a spring compressor. they are easy to get out, but as far as getting the coil off and on the new one requires compressors, you COULD take them off an somewhere and just pay them to swap the struts out on the assemblies, thats what i would do but ive done a few of em. do NOT take off that top center strut nut or youll have a missile on your hands. but just jack up the lower just a tad to relieve pressure like i said before an there should be a few bolts that hold the entire assembly in at the top and of course the 2 on the lower a arm. the rears should be much simpler.
id say go for the rears, since you know how to change shocks already, but as far as the struts dont try it if you dont feel comfortable. a shop bill is better than a hospital bill
Old 02-25-2011, 08:26 PM   #7
COBALT
COBALT's Avatar
I just checked, and yep, the strut goes through the spring and mounts to the upper spring mount on the frame just behind the upper A-arm. The lower A-arm exposes the lower mount.
I think I'll look at renting a set of spring compressors at one of the auto parts stores. I've worked with front springs before, but it was when I was pulling the lower A-arms out. I don't want those detached at the cross member. that's a whole other problem.
Seattle, WA.
Old 02-25-2011, 08:30 PM   #8
COBALT
COBALT's Avatar
Well, my birthday WAS yesterday AND I've got some funds. Maybe a little gift to yours truly is in order:
http://www.sears.com/shc/s/p_10153_1...2&blockType=G2
Seattle, WA.
Old 02-25-2011, 10:51 PM   #9
kSStamp0182
LSX addict
i have those as well, they work pretty good, im sure you could pick up a manual for your truck that would have a step by step too, thats always a huge help especially to find hidden bolts haha
Old 02-26-2011, 10:38 AM   #10
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
You don't need a spring compressor. Look at the bottom of your lower A arms, there should be 2 bolts holding the shock in place. Then on top there should be one nut you need to take off. Remove that nut then bolts holding the bottom and the shock should just drop out the bottom of the A arm. If you have the selectable ride option, it gets a little more complicated.
If you create an account at Autozone.com and enter you truck in, they have a repair guide section that covers it pretty good. Hope this helps.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-26-2011, 08:18 PM   #11
COBALT
COBALT's Avatar
I already have plenty of info on the rig, and as it turns out you're right I didn't need a spring compressor. I rented one and it basically just sat on the ground and watched me work. It was as easy as unbolting the nut on top, and dropping the two bolts below the lower A-arm just as described. The hard part was putting the new one in and not over-tightening that lock nut on top. Bilsteins come with a 17mm locknut on top and of course all of my nifty craftsman rachets are SAE, so I had to fudge it with a crescent wrench. Boo.
Those upper bolts on the rear shocks are a royal pain, but I got them in. The hard part on the backs was compressing the new shock enough to get that damn lower 13/16" bolt through the bushing.
But it's done and WOW does this thing ride better than it did.
Seattle, WA.
Old 02-26-2011, 10:41 PM   #12
Boog
laying low
Boog's Avatar
What do those Bilsteins run? I believe that's what comes with the Z71 pkg, right?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-27-2011, 05:29 AM   #13
COBALT
COBALT's Avatar
They're about $61 a piece now. I got them about a month ago for a bit cheaper.
Fronts:
http://www.shockwarehouse.com/site/p...lstein-GM-SUVs
Rears:
Seattle, WA.
Old 02-27-2011, 03:04 PM   #14
kSStamp0182
LSX addict
awesome thats good. i wasnt sure how the setup was but i figured it would just have shocks not struts. always better to have too much info than not enough!
