Closed Thread
Old 03-01-2011, 12:03 AM   #1776
nick martorano
Re: What did you do to your truck today!
Well Sunday morning I installed my new front suspension. I installed new upper and lower control arms, air bags and new 2" dropped spindles all from CPP. I also got the rear end re-installed with new trailing arms and drilled and slotted rotors and new posi unit etc. Also got my new wheels from Race Line with new BFG KDA's. I will post some pictures in the next days or so. Hoping to get the new LS3 installed this next weekend!
Pictures are posted in my album
nick martorano is offline
Old 03-01-2011, 02:15 AM   #1777
bollybib
bollybib's Avatar
Originally Posted by 67swb72klb View Post
i see that glass gas filter imo i would loose that thing they are not good had bad exp with em and heard about many others that have also !!
Ok thanks I'll keep an eye on it.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline
Old 03-01-2011, 03:00 AM   #1778
ItsRandy
ItsRandy's Avatar
Cleaned and painted the emergency brake pedal assembly and the flat plate that mounts with it under the dash.
ItsRandy is offline
Old 03-01-2011, 06:26 AM   #1779
Cambons
put the fuel tank back in and cleaned the hoses should have it started agian since the 7 years its been sitting
Cambons is offline
Old 03-01-2011, 11:04 PM   #1780
flashed
I drove it to the body shop thats going to do my rust repair to get my parts list in order and bought a perfect original Fleetside tailgate to go on it when its time. Now I have a spare if something happens later on down the road. Looks like my truck will be rust free very soon.
flashed is offline
Old 03-02-2011, 12:04 AM   #1781
Gene
Gene's Avatar
Got some more of my door rubber installed.
Gene is offline
Old 03-02-2011, 12:41 AM   #1782
Clutch442
Clutch442's Avatar
This is lame but I can't help myself, I drove mine to work today. That's always good.
Clutch442 is offline
Old 03-02-2011, 05:37 AM   #1783
mmmBoost
Tore down my tie rod ends and cleaned up the rest of the steering components
Always remember those that had your back
Never forget those that turned it
Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt,
Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner
mmmBoost is offline
Old 03-02-2011, 09:46 PM   #1784
kacz81
kacz81's Avatar
started the 69 camAro gas tank swap
kacz81 is offline
Old 03-02-2011, 10:01 PM   #1785
bollybib
bollybib's Avatar
I installed an OG 69 Guide Right side turn signal lens that I found on eBay. The old one was broken and then patched up with epoxy that yellowed.
I put a cigarette lighter into the socket. I bought a lighter assembly that came from a GMC from tll74 on this here site. I needed a lighter to fill the empty hole in the dash. It matches my Chebby just fine.
- Jim -
bollybib is offline
Old 03-02-2011, 10:14 PM   #1786
Jeffs70
Jeffs70's Avatar
worked on the finishing touches to gather a shape to my center console
Jeffs70 is offline
Old 03-02-2011, 10:52 PM   #1787
67Slider
67Slider's Avatar
kacz81,
Keep us posted on how it goes. I did this a few months back and I love it.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 03-02-2011, 11:16 PM   #1788
Slick67
Sofa King Crazy!!
Slick67's Avatar
Originally Posted by shawno72 View Post
^^^ Hey brand and part number are those headers? They look awesome!
#68608 Hedmann Heders from Summit, $333 shipped.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline
Old 03-03-2011, 01:38 AM   #1789
ItsRandy
ItsRandy's Avatar
Bought a Painless wiring harness.
ItsRandy is offline
Old 03-03-2011, 08:36 AM   #1790
kacz81
kacz81's Avatar
Originally Posted by 67Slider View Post
kacz81,
I'm using your thread in the faq section as a blueprint and would like to thank you for posting it so far its going together good
kacz81 is offline
Old 03-03-2011, 09:11 AM   #1791
longhorn396
S.D.M.F.
longhorn396's Avatar
i havent got to touch or dirve my truck for a week... ... gas is to expensive
1969 Chevy Longhorn 396/400 3/4 ton.
1991 Chevy Camaro RS 305/700r4
1978 Honda XL175 and XL350(the evil twin)
2006 Kawasaki ZX-14r drag bike-best e.t. 9.4@145 mph without nitrous
1971 BSA Thunderbolt 650cc
longhorn396 is offline
Old 03-03-2011, 10:47 AM   #1792
Sonicman
Sonicman's Avatar
Replace a bad exhaust/intake gasket on my 250 L6. There was an exhaust leak that sounded terrible. I repainted my shorty headers since they were off.
Sonicman is offline
Old 03-03-2011, 01:19 PM   #1793
glider_6969
You can say that again about the gas, it nuts over here, we are paying $1.18 per litre (there is about 41/2 litre to a gallon here) do the math..it bites.
68 Long stepper
My other ride ,,, 07 Streetglide..
glider_6969 is offline
Old 03-03-2011, 02:25 PM   #1794
shawno72
C/10 junkie
shawno72's Avatar
Thank you Slick67
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline
Old 03-03-2011, 03:24 PM   #1795
70s chevy
70s chevy's Avatar
block sanding on doors..(again, seams like i will never get done with block sanding) started working on fenders..and got jeep out of gararge and ran it for a bit..also got a box of goodies from H & H classics today..
70s chevy is offline
Old 03-03-2011, 03:27 PM   #1796
jjtackleberry
jjtackleberry's Avatar
Found out my trans filler tube is leaking at the trans....
Now trying to figure out how to fix it...
jjtackleberry is offline
Old 03-03-2011, 04:11 PM   #1797
68 TT
Still plays with trucks
68 TT's Avatar
Try to find one of the newer sleeve type seal filler tubes to replace the old O-ring style one on your truck. They run around $30 new.
I have made my own from junk yard donor parts when I couldn't get a new one to fit my needs. Cut off the sleeve type seal from the donor part and weld it to the original O-ring type tube. You have to cut some length off of the original tube to seat the seal properly and get the right fluid level reading.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline
Old 03-03-2011, 07:10 PM   #1798
LadyBird
Pulled the tired 350 and 465 trans out of my stepside this afternoon. Also sprayed down the engine bay and un bolted the radiator support. Makin some progress!
LadyBird is offline
Old 03-03-2011, 08:03 PM   #1799
Sinister
Between Trucks...
Sinister's Avatar
Fixed my aftermarket wiper washer pump. Simple fix, needed to come apart and a quick lube to the pump mechanism.
Beat it to fit,
Paint it to match...
Sinister is offline
Old 03-03-2011, 09:17 PM   #1800
flashed
Drove it for the last time possibly this year. She is coming apart for rust repair.
flashed is offline
Closed Thread
