Old 03-01-2011, 09:39 PM   #1
ubtripn
ubtripn's Avatar
Stupid question of the year
My truck is a stock 68, drum brakes all around and not altered in any major way other than paint. If I bought 4 tires of the same height and width, would the front ones stick out past the fender edge more than the rear? (Assuming the rear line up perfectly with the edge of the fender.)
ubtripn is offline   Reply With Quote
Old 03-01-2011, 09:46 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Stupid question of the year
Yes.
The track width of the front is slightly wider than the rear track width.
Keith
Convert to disc brakes.
Old 03-02-2011, 12:23 AM   #3
kcsa75
kcsa75's Avatar
Yes.
Even on the 2WD?
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 03-02-2011, 12:45 AM   #4
panda68
panda68's Avatar
i think the 2wd is even front and rear.
horsepower sells cars torque wins races. "caroll shelby"
panda68 is offline   Reply With Quote
Old 03-02-2011, 12:47 AM   #5
67chevy1series
67chevy1series's Avatar
yes 2wd and 4wd trucks front tires stick out wider than the back it isnt very noticeable but if you look for it you will see it
67chevy1series is offline   Reply With Quote
Old 03-02-2011, 01:17 AM   #6
David67
David67's Avatar
My front is about 3 inches wider than the rear. I have an ECE 4/6 drop so I wasn't sure if the spindles were what pushed them out or if it was like that originally.
'67 C10
David67 is offline   Reply With Quote
Old 03-02-2011, 08:35 AM   #7
lolife99
lolife99's Avatar
Originally Posted by kcsa75 View Post
Even on the 2WD?
Yep.
You can verify it with a tape measure.
Keith
Old 03-02-2011, 09:43 AM   #8
ubtripn
ubtripn's Avatar
Thanks for the data. My next question is WHY??? I know its not a big deal but it is enough to bother me, you can see it in the pics thread but I thought it might be a camera angle. What is the engineering advantage and more importantly how can I fix it?? I have heard talk of offsets. Do I need discs to fix it? Either way would work for me, push the rears out to match or fronts in to match. Please help me understand my options. Thanks.
FYI - It only bothers me because I can't stand uneven things, especially on the one vehicle that comes so close to perfection for me with its lines as this one does.
Old 03-02-2011, 10:16 AM   #9
stich626
it helps the car/trucks track straight,
stich626 is offline   Reply With Quote
Old 03-02-2011, 10:22 AM   #10
ubtripn
ubtripn's Avatar
I see. Still nothing like leaving 4 separate tire tracks in the snow (or in the is case wider ones.) That's not what bothers me though, its just the uneveness.
Thanks for the information.
Old 03-02-2011, 10:25 AM   #11
Transformula
Transformula's Avatar
Yeah, what he said. The wider front helps with stability and straightness. Ever see those 3-wheeled street cars? They have 2 wheels up front and one in the back. That's a very exaggerated case of the front being wider than the rear, but it works. Ever see those old 70's cars with stock size front tyres and super wide rears? They also didn't handle as well. Not to mention that they jacked 'em way up in the rear, reducing caster up front!
T.Y.N Custom Works..... Because "Stock" Sucks!
1971 K 10 GMC Long Bed
1977 Formula T/A Frame off Resto-Mod
1995 FXDL Harley Low Rider
1985 C10 ShortWide 91 Burb front.
Transformula is offline   Reply With Quote
Old 03-02-2011, 10:33 AM   #12
ubtripn
ubtripn's Avatar
That example helped me understand the physics of it.
Old 03-02-2011, 04:36 PM   #13
ubtripn
ubtripn's Avatar
Does anyone know how I can make them even while running the same size tire?
Old 03-02-2011, 04:38 PM   #14
lolife99
lolife99's Avatar
Add spacers to the rear wheels.
Keith
Old 03-02-2011, 06:25 PM   #15
ubtripn
ubtripn's Avatar
Thanks!
Old 03-02-2011, 06:35 PM   #16
tubbedII
needs more $$$
tubbedII's Avatar
lolife's is the simplest and cheapest way to get it done, but man, if that bothers you, the fact that the wheels aren't in the center of the wheel wells must be killer!
If you ever switch to discs in the front, it's just going to get worse to since they push them out about a half in on each side.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 03-02-2011, 06:43 PM   #17
69sixpackbee
I think the fact that there IS snow would bother the piss outta me
69sixpackbee is offline   Reply With Quote
Old 03-02-2011, 10:00 PM   #18
ubtripn
ubtripn's Avatar
You guys are funny, I get ribbing for what seems to be a small thing while there are others who are worried about period correct chalk markings on the firewall =) I guess we all have our own quirks or goals, mine is symmetry.
And thanks TubbedII, I hadn't noticed that till you said that. Hah! No solving that one. Well, at least its not as bad as my 66 where the front wheel wells are higher than the rear =)
Thanks again for the fix =)
Old 03-02-2011, 10:06 PM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
... I guess we all have our own quirks or goals, mine is symmetry....
If it makes you feel better, I suffer from the same syndrome. I don't know what its called, but unsymmetrical things really bother me.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-02-2011, 10:10 PM   #20
ubtripn
ubtripn's Avatar
Lol - it does.
Old 03-02-2011, 11:02 PM   #21
60ratrod
yes, i do
60ratrod's Avatar
its an O.C.D type. just like people that have to have their pants fly, belt buckle and button up shirt perfectly lined up at all times. the navy beats that O.C.D. into your head at boot camp. now when i wear a tucked in button up shirt, pants and a belt they all have to be perfectly in line or it bothers the fork out of me.
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 03-02-2011, 11:19 PM   #22
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Well then....the early Sixties had a custom trend that embodied assymetrical styling. Think Ed Roth.....Mysterion. Barris built one that had a slant 6 plymouth engine. There were a bunch, back then. Did I like 'em? They had their place in the automotive world, but I knew I'd never own one. The Art Deco style is more to my liking.
Member Nr. 2770
Old 03-03-2011, 07:22 AM   #23
68C15
blood type; Retumbo
68C15's Avatar
I think I would let it go. hard to see the wheels when sitting in the truck
68C15 is offline   Reply With Quote
Old 03-03-2011, 08:40 AM   #24
dave2953
Dave's not here, man
dave2953's Avatar
OCD for sure....although, my girlfriend and I call it CDO because we like for the letters to be in alphabetical order...the width differences have always bugged me too, so you aren't alone
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 03-03-2011, 08:42 AM   #25
lolife99
lolife99's Avatar
Drives me crazy also.
That's why I alway run a wider wheel on the rear.
Keith
