Old 03-02-2011, 10:32 PM   #726
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
Why not use the stock Vortec muffler from 96-up dual in and single out. Fairly efficient and mellow
Originally Posted by 68 TT View Post
Along the same lines, why not go with a stock 2002 truck muffler since you have that theme going already.
Off the shelf replacement mufflers should give you some choice of sound level and they will all be relatively the same size so swapping one for another will be a piece of cake.
You probably have a stock one or two sitting around that you can build the exhaust system around to get you started.
I am moving in this direction, glad to hear ya'll agree. I was investigating sounds of the 2 trucks that I have with the stock setup. The 6.0 Denali vs. 5.3 is significant. The 6.0 definitely has a little burble and the 5.3 does not. A quick look underneath revealed the the 6.0 muffler is different - soooo, since I have a complete 6.0 exhaust system from a Yukon with the dual inlet muffler like I listened to - I'll be scrapping what I did last night. No biggie since I only spent an hour on it. I'll get that system loose this weekend and delete the cats on it again. The muffler is dual in - dual out, but on a Yukon it converges into 1 right after the exit. I wonder what it sounds like separate vs. merged?
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 03-02-2011, 11:25 PM   #727
pickup67man
pickup67man's Avatar
Like your idea of 4 link in rear. I want to use a newer chassis for my suburban also and the wheelbase will be different no matter what I use (stock is 127"). That makes the change in wheelbase easier with the good ride.
Travis
2005 K2500 Duramax (hauls the junk home)
1967 Chev C10 (hauls a$$)
1970 Suburban (Yukon XL 4 door)
1968 GMC 3/4 ton (sheetmetal only, chassis gone)
2005 Malibu (wife's car, still a Chevy)
Project Family Hauler
New Home for Chevys (Moved in and working)
pickup67man is offline   Reply With Quote
Old 03-03-2011, 12:18 AM   #728
drewskiren
drewskiren's Avatar
Exactly!
Drew
Old 03-03-2011, 12:20 AM   #729
Rokcrln
Rokcrln's Avatar
On my 5.3L in LowBuk I have stock camaro manifolds with 2.5" duals out to a 3" merge right behind the trans then it goes from their the single pipe goes to the flow master in and out. It is mellow but you can tell their is something under the hood that is not stock.
With that being said I think with your build I would go with a stock set up you have around their and down the road you can swap out for a cat back set up that is made for your truck if you want a change.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 03-03-2011, 10:00 AM   #730
drewskiren
drewskiren's Avatar
Kevin
LFD Inc.
I agree, I've got a free exhaust system, why not use it. I can always change it later when I'm bored with it.
No cats on yours? How does she run??
Does anyone know if you gain much by deleting the cats?
Drew
Old 03-04-2011, 12:13 AM   #731
drewskiren
drewskiren's Avatar
And now for my next trick.
Size:  44.5 KBName:  DRW_6618.jpg
I am too cheap to buy an aftermarket air system since they are over $1000. I have 3 of these new style units left over, and it is factory engineered ready to plug into my harness. I'll have to make it fit somehow if it kills me.
Drew
Old 03-04-2011, 12:26 AM   #732
swamp rat
swamp rat's Avatar
Get a shoe horn!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-04-2011, 12:58 AM   #733
jbclassix
Junk Yartist
jbclassix's Avatar
I just watched despicable me and I think Gru had a tool you need
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 03-04-2011, 01:12 AM   #734
drewskiren
drewskiren's Avatar
Yes, a shrink ray would be quite handy about now.
Drew
Old 03-04-2011, 02:08 AM   #735
VA72C10
VA72C10
VA72C10's Avatar
Have you looked at what they run on the used parts market? Maybe you can sell them and pick up a vintage air with the money?
Old 03-04-2011, 08:48 AM   #736
hgs_notes
GEARHEAD
hgs_notes's Avatar
You've done some terrific work on this project, but I don't think that unit is going to fit under your dash.
hgs_notes is offline   Reply With Quote
Old 03-04-2011, 09:52 AM   #737
ERASER5
ERASER5's Avatar
Yea. Until the unit re-expands after install and tears the truck apart.
I tend to over analize cartoons. It's a sickness.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-04-2011, 10:14 AM   #738
drewskiren
drewskiren's Avatar
These factory AC systems never die and never get smashed in a wreck, so there is no market for them at all - that's why I still have 3.
I think I can, I think I can, I think I can......
Drew
Old 03-04-2011, 10:26 AM   #739
67cheby
67cheby
67cheby's Avatar
i dont think you are trying to save money ....i think you just like the challenge of seeing if you can get it in there !!!!! YOU CAN DO IT !!! then you will have pass and driver climate control ...how cool is that
67cheby is offline   Reply With Quote
Old 03-04-2011, 10:49 AM   #740
drewskiren
drewskiren's Avatar
[quote=67cheby;4529326] I don't think you are trying to save money ....I think you just like the challenge of seeing if you can get it in there !!!!! YOU CAN DO IT !!!
Hmmmmm, I think you may be right.
Drew
Old 03-04-2011, 03:26 PM   #741
68 TT
Still plays with trucks
68 TT's Avatar
What about pulling the stock dash off the firewall, fit up the A/C unit then reinstall the stock dash over the top. You could then locate the stock metal dash panel a little farther off the firewall than it was stock to give you the room you need. Some metal filler panels on the dash top and sides will be needed but it can still look stock when you are done, just stretched a little.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 03-04-2011, 03:50 PM   #742
drewskiren
drewskiren's Avatar
I like it, sounds like a good fallback plan. Nobody would ever really realize the change I suspect.
Drew
Old 03-04-2011, 05:54 PM   #743
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
As long as the dash isn't in the middle of the doorway....
Much talent in this build, thank you again for sharing!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 03-04-2011, 06:28 PM   #744
JasonBird
'67 C-10 LWB Driver
JasonBird's Avatar
lol, i think the back seats just got smaller!! JK ;-)
'67 C-10 LWB - My Build Thread
'67 C-20 LWB - My Donor/ Parts truck - SOLD!
'92 GMC SAFARI VAN - My Parts Go Getter
'06 KIA SPORTAGE EX - My Commuter
"All of this crap better make a truck!" - my wife Sue.
Proud U.S.M.C. Dad!
JasonBird is offline   Reply With Quote
Old 03-04-2011, 07:50 PM   #745
drewskiren
drewskiren's Avatar
Abracadabra
POOF
Drew
Old 03-04-2011, 07:56 PM   #746
67chevy1series
67chevy1series's Avatar
wow that is awsome yes gru did have the tool you needed well i hope it works better than it looks.....that looks kinda ugly... but its ugly because it was kept inside anewer dash.....anyways drew great progress
67chevy1series is offline   Reply With Quote
Old 03-04-2011, 08:01 PM   #747
VA72C10
VA72C10
VA72C10's Avatar
Nice job shoehorning that in
It doesn't stick down that much lower than a stock A/C box actually...probably 3-4" or so more....
...are you going to be able to integrate the controls somehow?
Old 03-04-2011, 08:17 PM   #748
Pop's C-10
Pop's C-10's Avatar
Nice...who needs a glove box anyway....lol
You running beanch or buckets...
Pop's C-10 is offline   Reply With Quote
Old 03-04-2011, 08:23 PM   #749
JasonBird
'67 C-10 LWB Driver
JasonBird's Avatar
that is some nice photoshoppin'!!
Proud U.S.M.C. Dad!
Old 03-04-2011, 08:34 PM   #750
67chevy1series
haha
