![]() Join Date: May 2010
i don't know how i did it but i need help to fix it
![]() here's the problem. using my stock spring plates i don't have enought clearance to put the shock extender on the mounting bracket. (i was sent the wrong shocks anyways but still i need shocks on the truck. with the stock spring plate on and no shocks on my pass side is sitting a good 1 to 1.5 inches lower then the driver side. what did i do wrong? how can i fix this? why is it so hard to just flip a rear end. i have done flips befor and never had a problem. |
Happy to be here
![]() Join Date: Mar 2000
Re: i don't know how i did it but i need help to fix it
My first thought is are you SURE it was level before? Its not uncommon for these trucks to have a lean thats not noticed until its lowered.
If you are sure, its possible the new bushings, painted leaves, etc are binding enough to cause it. It might settle once you get some drive time on it.
67-72 parts collector,…
![]() Join Date: Nov 2002
When you tighten the leaf spring bolts,... ALL of the trucks weight needs to be on the truck.
Did you perhaps tighten the leaf spring bolts with the truck in the air with no weight on the leaf springs? Maybe you preloaded one side more than the other.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-03-2011 at 07:20 AM. |
thanks for the info guys. I went and got the right shocks and that brought it up alittle to match but the pass side is still down about half an inch but i didn't put the weight of the truck on the springs when i tightened them so i will redo those.
I do have another issue: (I hope someone can help with this) I took the truck out for the first run around the block and i have a hard clanging sound when i step on the gas every now and again. Any ideas? |
