#76 |
Re: Let's see the 1 ton 4x4s!
Where did you get these adapters at?
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
#77 |
Check our arrowcraft.com They offer adapters for everything.
There are lot's of manufactures of adapters. Just do a google search for "wheel adapters' and you'll see. Most of the adapters I found were made of aluminium but my choice was steel. They work great. |
#78 |
#79 |
Since this is a 1 ton truck with 4x4 thread I will post some of mine.
My 77 and 79 Silverados both had 400 sb, T400, and 203 transfer cases, engine/transmission oil coolers, and optioned wood floor beds with bed mounted spares. The 77 had 4.10 rears and the 79 with 3.73's. I bought a SAE part time kit for the 79's transfer case and installed Husky Selectro hubs. I had the 79 longer than most of my trucks back then and eventually installed the Featherlite 96x108 flatbed. I kept moving the modified for spare Jackman grille guard from truck to truck. |
#80 |
I wish I could find more pics of my 1980. It was ordered with the chrome wheel option. It had a 400 sb, T400, and a 205 transfercase with the factory Spicer lockouts, and 3.73 rears. I moved in 1981 and some things got lost/destroyed at the time,(pictures/albums).
All my dually K30's had the commercial duty 5 spring package of extra helper leafs except the 77. It had 6 leafs. Next is my 1986 M1008. It had the 6.2 diesel. T400, and 241 transfercase, with 4.56 rears. Currently the blown 6.2 has been removed while I ponder it's next power plant,(Cummins?). It was a nicer ride after the installation of the 255/85 BFG Muds. |
#81 |
Here is my 1988 2 door, regular cab V30 pickup. It was built at the Janesville, WI. plant in May 1988. It has a 454, T400, 205 transfercase, and 3.73 rears. It has the record of being my longest owned vehicle of the 100+ I have had.
#82 |
Dooley, you've had some sweet trucks. Really like the '80 and the '88.
#83 |
Currently Blazerless
I agree!! Looks like you used them for what they were made for! I espicially like the yellow 77...perfect workhorse/weekend toy
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
#84 |
Here's my 84, 454, th400, np205 with 4.11s. Its my next project after my 72 gets put back together.
Professional hot glue and pop cycle stick engineer. 72 K/20 soon to be C/10, 454, Th400, 9” rear. 01 GMC 2500HD 8.1, Allison, daily/towpig gas guzzler. 78 Bahner 19’ jet boat, 460 Furd turd. |
#85 |
![]() Join Date: Aug 2010
It is not a PK/UP but it is on 1 ton axles...
I just finished up a GM 5.3 swap into the truck and I replaced everything from the fuel tank to the fuel rail on the motor with new parts. The fuel system is all plumbed in -06 Aeroquip socketless hose and -06 socketless fittings. I replaced the tank with a brand new tank and sending unit for a 1991 Jimmy and put the pump in the tank. I used a Holley/Walbro 255 LPH in tank pump and a regulator/filter from a 99 to 03 Vette. I am the 4th owner of this truck and this truck is an original Arizona truck so there is very little rust on it at all. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Specs : Dana 60 front Lock Right 1/4 Diff Cover 4:56 gears New rotors, calipers and studs New Wheel bearings King Pins reworked 2.5 inch BDS front springs ORD HD grease able shackles ORD sway bar dico ORD Steering box brace 14 Bolt rear Detroit locker 4:56 gears 1/4 Diff cover U joint / yoke rock guard Rear disc conversion New bearings and seals shock mounts moved axle perches moved 4 inch BDS rear springs ORD HD grease able shackles Built TH400 6 bolt round adapter 6 bolt round NP 205 New bearings, gaskets and seals in the NP 205 New 17X9 Pro Comp 1069 wheels with new 36X13.50X17 Irok bias tires. The tires have 27 miles on them and measure out the same as a 37x14.00X17 Irok which is 36.8 inches. Hydoboost brakes The inside of the tub has been Line X'ed 3000 watt continuous 6000 watt max inverter New 31 gallon fuel tank with skid and very nice rear offroad bumper Coated Street and Performance headers for a 5.3 swap into a 1973 to 87 GM Truck with a single Dynomax x flow muffler and no cats. The truck sounds great New Taylor 10.4 wires, Taylor plug boots and with Bosch Platinum plugs Flushed out the engine when we swapped it in and all I have ever ran in the motor is 5W20 Royal Purple oil. And here is my old single wheel K30... ![]() Started life out as a CUCV 6.2 was pulled 454 put in it's place. |
#86 |
1tonjimmy - Very strong looking K5 you go there!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
#87 |
71' Jimmy - D60, 14BFF, 203/205 Doubler ETC
71 ![]() |
#88 |
Couple of pics of my 98 Z71TON
#89 |
not specifically a chevy, but if you did an x-ray you would find it is mostly a chev. tbi 454 nv4500 205 60F/14FF technically its a 5/4 ton, but that is splitting hairs
#90 |
love the look of your rig!! What engine and tranny does it have?
67 C20/ 68 C10 stepside/inline 250--current project 71 GMC 4x4 70 Blazer project-Zombie assault vehicle 67 4x4 Burb ![]() |
#91 |
Next!
Here is my latest K30, picked up last week, put two batteries in it started right up. Military conversion of a M1031 cab and chassis to a M1028a2 dually pickup. Dana 70 rear rear, Dana 60 front, NP205, TH400, 6.2., etc. This may actually be a keeper.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
#92 |
Chevy Enthusiast
I don't know how I forgot how to subscribe to this one. Nice trucks guys!
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
#93 | |
71 ![]() Last edited by RckyMntnKng; 03-08-2011 at 05:58 PM. |
#94 |
high-Tech Red Neck
Now a member of the club as of... today!
"He used to be a pretty nice feller, now he's a welder!" |
#95 |
Cool! looks like a good start for a dually project..whats your plans?
#96 | |
high-Tech Red Neck
#97 |
What is that frame out of?
I may be able to get back my first truck.. a 55 Chevy 1 ton panel, and I wanted to go 4X4, Cummins, NP4500, etc.. The frame looks about right. |
#98 |
72 cst k5
72 K5 CST |
#99 |
My 1991 V3500
6.2L diesel, 4L80E, NP205, 14bolt FF, Dana 60 No lift with 285/75/16's ![]() ![]() Posted via Mobile Device
#100 |
K5 now rollin' on 1 tons & my husbands M1031 that's in progress!
