Old 03-02-2011, 01:29 PM   #1
bobcostas
bobcostas's Avatar
Knee Freezer AC install
Hey Dudes!
I am attempting to install an under-dash AC unit I got off eBay about a year ago. Its a very used model that they said came out of a '63 Caddy. I think i got everything in order, except one thing. This genius thought the evaporator unit would fit. My deluxe heater is in the way
Does anyone have one of these style AC evaporators with a deluxe heater. I also have a granny 4-speed, so I think putting it in the center is out of the question. Am I boned?
Thanks guys
'64 Corvair Ragtop
'66 C10 Stepside
"The oxen may be slow, but the Earth is patient"
bobcostas is offline   Reply With Quote
Old 03-02-2011, 02:04 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Knee Freezer AC install
I only have information on the 1960 model. Although it doesn’t state one way or the other, it seems apparent if you wanted factory air in 1960 a heater wasn’t an option because the A/C unit occupies the same space. For models with a floor shift, the evaporator was mounted in front of the passenger seat. For an aftermarket, or conversion from something else it’s going to be a matter of what will fit, which probably isn’t going to be in the middle with the factory floor shifter. Hopefully someone else has an install to share, but thought this might help:
Old 03-02-2011, 03:15 PM   #3
bobcostas
bobcostas's Avatar
Thanks Mark!
I'll study those pages.
'64 Corvair Ragtop
'66 C10 Stepside
Old 03-02-2011, 03:16 PM   #4
kieth
kieth's Avatar
Will it fit under the seat ? if not I have two units in the back of 91 model suburbans that might work...........for free............
Originally Posted by bobcostas View Post
Hey Dudes!
Thanks guys
kieth is offline   Reply With Quote
Old 03-02-2011, 11:16 PM   #5
awbrown
I never thought about the under seat units , do you have a picture or some dimensions?? I was given a late model 350 with all the accesories on the front and am contemplating doing the ac swap ...thanks
awbrown is offline   Reply With Quote
Old 03-03-2011, 11:59 AM   #6
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
The Cool Pack accessory could be installed under the center of the dash for automatics and 3 speeds. If you had a four speed the unit installed under the glove compartment. The Caddy condenser is close to the dimension ( right width but a row of coils to much in height.) for the trucks, but utilized a different drier. The mounting brackets from the Caddy condenser can be removed and new brackets can be fabricated. I'm piecing this stuff together for mine. I have the compressor brackets for an inline 6 that are cast but in 63 the brackets were pressed steel . Just missed out on the correct setup on ebay. Hate being broke and unemployed when this stuff comes up for sale.
Old 03-03-2011, 07:11 PM   #7
kieth
kieth's Avatar
Here is the unit at the rear of the 91 burb, I have anothe just like i out of a 88 burb, all the other connections to this unit are just like the regular A/C, I was just joking around but this would work with some engineering.......
http://kieth.smugmug.com/Trucks/66-G...251_DEtG5-A-LB
Old 03-03-2011, 09:44 PM   #8
LT1 Burb
LT1 Burb's Avatar
PM me Aerotruck about a condensor, I have an extra.
LT1 Burb is offline   Reply With Quote
