Old 03-04-2011, 10:14 AM   #1
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
Originally Posted by VA72C10 View Post
Have you looked at what they run on the used parts market? Maybe you can sell them and pick up a vintage air with the money?
These factory AC systems never die and never get smashed in a wreck, so there is no market for them at all - that's why I still have 3.
I think I can, I think I can, I think I can......
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 03-04-2011, 10:26 AM   #2
67cheby
67cheby
67cheby's Avatar
i dont think you are trying to save money ....i think you just like the challenge of seeing if you can get it in there !!!!! YOU CAN DO IT !!! then you will have pass and driver climate control ...how cool is that
67cheby is offline   Reply With Quote
Old 03-04-2011, 10:49 AM   #3
drewskiren
drewskiren's Avatar
[quote=67cheby;4529326] I don't think you are trying to save money ....I think you just like the challenge of seeing if you can get it in there !!!!! YOU CAN DO IT !!!
Hmmmmm, I think you may be right.
Drew
Old 03-04-2011, 03:26 PM   #4
68 TT
Still plays with trucks
68 TT's Avatar
What about pulling the stock dash off the firewall, fit up the A/C unit then reinstall the stock dash over the top. You could then locate the stock metal dash panel a little farther off the firewall than it was stock to give you the room you need. Some metal filler panels on the dash top and sides will be needed but it can still look stock when you are done, just stretched a little.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 03-04-2011, 03:50 PM   #5
drewskiren
drewskiren's Avatar
I like it, sounds like a good fallback plan. Nobody would ever really realize the change I suspect.
Drew
Old 03-04-2011, 05:54 PM   #6
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
As long as the dash isn't in the middle of the doorway....
Much talent in this build, thank you again for sharing!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
