Re: 383 with no oil pressure
I have a slight tick but the headers I have are cheap and I contributed it to the head tick on thin wall headers.
No major noise which I would think would be there after 4 miles of driving.
2013 Chevy Silverado, Z71, 5.3L, 4 door 2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40 Support the Troops. ![]() |
#2 | |
I just went through a similar situation with my Dodge truck (which I am selling). It had a fiber filter element on the bottom of the oil pickup. When that clogged up it sucked the filter in to the pick tube and the oil stopped flowing. I was sure I had a bad sender or gauge, but that was not the case. I shut it down, replaced the pickup and oil pump and all is well.
Randy Summers Never brake in the learning curve! 1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737 Last edited by sumran; 03-04-2011 at 01:58 PM. |
What does "no oil in the tube" mean? There is no oil in your oil line? Check for kinks like a previous poster mentioned.
Before you go through the trouble of pulling a valve cover and making a mess, you can check your dipstick, wipe it clean and re-check the level. Then run the truck a minute, shut it off and re-check the dipstick. Oil should have found it's way farther up, much farther. Just pulling a valve cover and seeing oil squirt out isn't a very good indication of the amount of pressure present, neither is checking the dipstick, you will need to check your gauge and wiring before you go further than just looking for oil flow. But at least you know it is flowing somewhat.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip '68 Plymouth Road Runner 383, 727, 3.23 Sure Grip '89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip '77 Dodge Monaco ex cop car 440, 727, 2.71 '79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip '12 Dodge Challenger SRT8 392, M6, 3.92 '85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73 |
#4 | |
Ok....then trace the line back to the sending unit, not really a big deal. If you don't find anything, then you may have other problems.
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 03-05-2011 at 11:36 AM. |
