aftermarket hoods
Hey for you guys with aftermarket hoods, have you had problems with fit? I know fenders only fit right 1% of the time right out of the box, but what about the hoods? Thanks
Low68
Build Thread |
![]() Join Date: Feb 2001
My cowl hood doesn't fit to my expectations.................Oh well!
I'm not real thrilled with the fit of my cowl hood either.
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
![]() Join Date: Dec 1999
Did you guys buy Goodmark or Tri-Plus?
I am not sure what brand mine is but I bought it from GMCPaul. It fits very well.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
I bought mine from Tuckers in Las Vegas. They told me is was a Goodmark. When I got it home I couldn't find the Goodmark name on it anywhere. I called Jerry the owner and he told me it was a Goodmark and thats all he sells. So I don't know what brand it is because I thought Goodmark stamped the name on theirs. Anyway it fits pretty good. If I spend some more time adjusting I could get it good enough.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
Senior Moment
![]() Join Date: Mar 2002
Mine fits good, could be a bit better but I'm happy
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
I bought mine and it came in a goodmark box but is stamped triplus. Fit great.
Tri Plus. It sucked ! I took it back
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
My Hood is a triplus, it's the same hood as a goodmark. You can guess where I got it. Took me all of 20 minutes to have it on and aligned. Fits better than my original.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
"Trucks with Class"
All The Same!!!
Goodmark, Triplus, Counterpart are all the same. There is only one factory stamping these...and like any repop part you have to make them fit!!!
![]() Join Date: Mar 2003
I had lots of problems with the goodmark cowl hood, doors and fenders. After spending all that money I ended up buying old doors. I would never buy Goodmark products again. I would have been better off buying beat up Junk at a junk yard and repairing it. Good luck.
68cst_ss490
my cowl is a good mark and it fits quite well.
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
I had the same problem as blue4x4. And I would have to say the same thing. I will never waste my time and money on new sheetmetal again.
68 short fleet with 71 front clip 2wd jaguar blue ![]() 99 chevy ext cab shrtbed z71 loaded ![]() 99 chevy swb fleetside(daily driver) ![]() Sparks, Nevada |
#15 |
Cowl Hood
Mine fits like crap. I don't know if it's the hood, the truck or what. I have a Tri Plus hood. I have tried everything but putting it on "Naked". My last resort will be having the frame checked for damage, then installing the parts I have already installed, a 67 radiator support (also a tri plus piece) then measure in a cross pattern from the cowl mounting screws to the screws on the top of the radiator support (to check for squareness) then reinstalling the fenders, grill etc. to see it if it at last will fit. Mine leaves a gap between the bottom of the hood and the top of the grill in the middle at the front. Also there is a gap between the fenders and the hood on the top front. Any help will be greatly appreciated.
Richard Dobson |
#16 |
Sounds a lot like mine. Three body men worked on mine all afternoon and finally gave up. Most don't notice but I do so I know others notice too that know what they are looking at.
#17 |
GMC PAUL AND CHRISTAIN,S...Any comeback?What is the TRUE story behind Goodmark,Triplus..Fein Cheng and whomever else sells repro parts.Please let us know!!!!
#18 |
Triplus makes Goodmark 67-72 Cowl Hoods. They are just in a Goodmark labeled box.
Les @GMCPauls
#19 |
Shouldn,t Goodmark be stamped on it somewhere?Doesn,t a Goodmark product cost more than Tri Plus?I was under impression that anything that Goodmark sold was licenced to be as close to an original GM product or made from original tooling.
#20 |
"Trucks with Class"
Sider68 I would help you with that, but I guess you don't believe me...You only wanted answer from GMC P & Ch...The same answer I gave up a couple posts earlier!
#21 |
I have noticed in our restorations lately the last 6 67-8 cowlhoods is a little bowed in the center and the passenger door is wider at the rear post on the reproduction parts, the next load should be corrected they tell me. GM has no control over aftermarket parts quality,only the manafacturer controls the quality on GM restoration parts i.e. TRI PLUS.
Rest in Peace Ed. Thanks for all the good times. |
#22 |
My goodmark cowl hood fits great. Really no complaints here.
1968 Chev SWB with 1998 Corvette LS1 305hp and 320 ftlb to the wheels (stock engine!) AEM EMS and wideband O2 sensors Bowtie Overdrive's 700R4, stage 3 Baer 4 wheel discs and 20s http://iciclelanding.com/aperture?album=2049&view=album |
#23 |
Cowl Hoods
I am trying to put a 68 front end with the cowl hood on a 71 C10 with a 67 tri plus radiator support. Would I be better off staying with the 71 front end with a Cowl hood for it, are the cowl hoods and radiator supports for 71-72's better as far as fit-up goes? I like the 67-67 a lot, it looks more streamlined to me.
Richard Dobson |
#24 |
"Trucks with Class"
Good or Bad???
Look at this so far. Seven say they are good to great and seven say they are bad to terrible. How is that possible? I have found they are not perfect, but they are very good and really look cool.
One of the problems we are having with repro parts, is the "installers". Plain & simple, some guys can't get them lined up, if they need adjustment. It is not just a bolt on and drive away job. Good body people are doing very good with these parts but "painters" are complaining. "painters" are specialists in sand & shoot and can't do much body work. Check out your painter and find out if he can do good bodywork or just paint jobs. |
#25 |
Thanks for all the replies guys. I haven't decided yet if I am going to get one. I would be putting it on myself if I did.
Low68
Build Thread |
