Old 03-05-2011, 06:24 PM   #1
Dova
Dova's Avatar
Door lock removal/reinstall help
I've looked up a few threads but didn't find anything with my issue. So i'm reinstalling new door locks for my 67 K10 and the "pawl" wont catch onto the "C" notch I guess you would call it. Any help would be appreciated. I've never seen the door locks work because the previous owner did not have the keys. Thanks in advance.
Dova is offline   Reply With Quote
Old 03-05-2011, 09:05 PM   #2
JimKshortstep4x4
Re: Door lock removal/reinstall help
The "pawl" has to be oreinted for the door, (left or right door) so I suspect that the "pawl" needs to be changed. The other thought is that the door locks are not matched to the correct door.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-05-2011, 10:56 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Here are a couple of pictures. Like Jim said there is a right and left.
First one is what your pawl should look like and the second is how it should set in the latch. If you roll the window down you can see the latch with a good flashlight...
LockDoc
Leon
Old 03-06-2011, 12:26 PM   #4
Dova
Dova's Avatar
LockDoc
Thanks, when I do look in there that is what I see. I pulled the passenger lock and tried to install the new one. Maybe I was using the wrong replacement one. I'll be trying it again in a little bit. Thanks again.
