Closed Thread
Old 03-05-2011, 05:52 PM   #2651
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: What did you do to your truck today?
Originally Posted by lakeroadster View Post
I like the idea as far as sealing everything to prevent moisture from getting into cracks.
I am wondering, does it "off gas"? Meaning will it release funky, maybe toxic, fumes that you will be breathing in the cab? Probably not any worse though than epoxy paint.
Just a thought..
Interesting thought. It is thinned with xylene<sp>. I would think when it dries and that evaporates, the gas/smell would be gone. It was kinda smelly when I put it on, but so was all the other paint in there.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline
Old 03-05-2011, 05:59 PM   #2652
lakeroadster
Finished up the hidden radio today, hooked up the antenna, finished assembly of the console and reinstalled the passenger seat.
Installed a CB antenna in the original fuel filler location. An "era correct" addition (CB Antenna). More photos and data in my build thread.
lakeroadster is offline
Old 03-06-2011, 12:01 PM   #2653
kieth
kieth's Avatar
Started blasting the bed today..........................here are a few pics.....one cannot sand this fast........
http://kieth.smugmug.com/Trucks/66-G...07426574_ogvuC
kieth is offline
Old 03-06-2011, 03:29 PM   #2654
70inline6
Took my old starter to Autozone and had it tested.... LOL It sounded like a coffee grinder in their machine and tripped the safety breaker. Tested the new one I bought... spun and sounded like a high power air drill... nice.
Installed the new starter and new wire harness.... one thing at a time.
70inline6 is offline
Old 03-06-2011, 06:13 PM   #2655
kirtzen
kirtzen's Avatar
replaced drivers door bottom.
Name:  door repair.jpg
Name:  door repair 2.jpg
kirtzen is offline
Old 03-06-2011, 07:09 PM   #2656
willyp
willyp's Avatar
tore out the seat and old carpet, sand blasted the instrument bezel and painted it, reinstalled the tacho, sound deadener and scored matching chrome choke knob and cigarette lighter at the junk yard for $10.
The price of cool aint cheap.
willyp is offline
Old 03-06-2011, 11:56 PM   #2657
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Refinished my speedo today. Just need to finish the fuel and temp gauges and paint the needles fluorescent orange
You can see more pics on my build page.
Tony
Tony
66 GMC LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=399283
AZ66GMC is offline
Old 03-07-2011, 09:00 AM   #2658
61_FL_Apache
Who Me?
My cab is about 90% complete and its back on the road today.
Steve
2001 Blazer 4D 2WD
Old 03-07-2011, 09:10 AM   #2659
lakeroadster
Man that sure came out nice.....
Old 03-07-2011, 11:20 AM   #2660
tenni126
Changed out the door lock cylinders and got the new wing window seal in on the drivers side. Here's a little tip in case anyone is considering the seal replacement: Don't.
I did get it in, but it took a LOT of messing around. I'll post pics for the other side, as it should go quicker after the learning curve. It's not all that bad in hindsight, but requires a few rivets drilled out, and some 'creativity' on re-assembly, due to differences in the aftermarket parts.
tenni126 is offline
Old 03-07-2011, 01:35 PM   #2661
steverino66
Finally finished driver's side of bed where I removed the old chain mounts - eliminated holes and latch cutout areas; started passenger side but ran out of MIG gas (bigger bottle?)!
Also patched the hideous hole where the antenna was…
steverino66 is offline
Old 03-07-2011, 03:44 PM   #2662
Bugeyev8
Bugeyev8's Avatar
the bigger gas bottle costs almost as much as the little ones, my gas shop let me trade in the smaller one for the larger one, All I had to do was pay for the gas, also check and see what the gas settings are should be about 12 inside and up to about 15-20 outside
Bugeyev8 is offline
Old 03-07-2011, 03:53 PM   #2663
steverino66
Thanks. I got my little 20 cu. ft. from NAPA, only costs me $16 for refill - I'm using (wasting) less as I get better at welding, so I'll certainly check on the bigger one.
Old 03-07-2011, 03:57 PM   #2664
Bugeyev8
Bugeyev8's Avatar
Got the heater panel painted and the glove box door re painted, the weather finally got in the temps where the paint will work, not perfect but not too much dirt in the paint...
Bugeyev8 is offline
Old 03-07-2011, 06:17 PM   #2665
kieth
kieth's Avatar
She's Naked--------------call this the stripping thread
Kieth
kieth is offline
Old 03-07-2011, 06:19 PM   #2666
61_FL_Apache
Who Me?
Kieth
WOOHOO!!!!! Show some
Steve
2001 Blazer 4D 2WD
Old 03-07-2011, 08:53 PM   #2667
Hipper
Hipper's Avatar
wether was nice enough took the fork lift and got the diff out of its hidding place and placed it on the flat bed of the 65 dually. Now to just get it under the bed insted of on it.
71 GMC Long Bed, 454,factory everything, lowered, and shaved.
64 GMC Short Bed (great grandfathers truck)
65 Chevy 1 ton Dually a/c p/s p/b v8 auto
89 Jeep Cherokee 3" lift
79 MG Midget (My 7 year old vehicle)
29 Ford Model A Rat Rod (in the works)
86 pontiac fiero 2.5 manual18 year olds)
87 pontiac fiero SE 2.8 auto (18 year olds)
90 Mitsubishi eclipes turbo AWD (18 year olds)
69 BMW 1600 (wifes toy)
Hipper is offline
Old 03-07-2011, 09:04 PM   #2668
jbgroby
jbgroby's Avatar
Spent the day in the following manner:
1. Spent about 2 hours trying like hell to figure out why the gas pedal linkage would not line back up with the carb throttle, removing the linkage and turning it around - Had installed the relay backward after painting it 6 months ago.
2. Spent an hour mounting the wiper motor and trying to remember how the relay linkage was laid out. Had to refer back to the pictures I took 4 years ago. TAKE PLENTY OF PICTURES!!
3. Spent 3 hours installing the interior defroster/heater combo and under dash heater box
3. Spent an hour installing glovebox liner, light, bumpers and door.
jbgroby is offline
Old 03-07-2011, 11:48 PM   #2669
198plus
198plus's Avatar
BBC installed............
198plus is offline
Old 03-08-2011, 12:02 AM   #2670
bubba327
HOW long until spring??
bubba327's Avatar
What did I do to my truck today???
I took a picture of it cuz it looked really good as a daily driver parked in the high school parking lot.
I am proud of my daughter that she loves driving a 64 truck!
I was delivering a forgotten lunch.
And it is still winter in Idaho
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline
Old 03-11-2011, 10:00 PM   #2671
TopFuel1966
TopFuel1966's Avatar
I took the ol' girl on her first checkout drive. Still lots of work to be done but she drives OK.Name:  66c10_020.jpg
TopFuel1966 is offline
Old 03-11-2011, 11:14 PM   #2672
evobuilder
evobuilder's Avatar
got my truck dialed in..... runs freakin awesome.... EXCEPT..... it seems the float levals are still off a little. I will take running 90% better, then how ****ty it was running before. Now its time to get my temp gauge working, it never ends!
Evobuilder / Seattle, WA
Hub Garage: www.hubgarage.com/mygarage/evobuilder
evobuilder is offline
Old 03-11-2011, 11:37 PM   #2673
jbgroby
jbgroby's Avatar
Got the day/night Mirror installed, the transmission cover in place, the bench seat mounted, the choke cable routed and the gas pedal mounted with brass screws so they never rust. Also I created an album for your viewing pleasure called "Fal-Tor-Pan, The Reassembly". Those of you who are Start Trek fans will know what I'm talking about.
http://rides.webshots.com/album/579894970vydbSl
Fal-Tor-Pan, the Re-fusion. This ritual was performed on a 1960 GMC 305 V-6, 127" wheel Base Wideside Pickup in 2011. The ritual was considered very EXPENSIVE, both to the Owner of the Truck and to the keeper of the Katra, read "Purse". For this reason, it was almost never performed and at the time of Jake's Fal-Tor-Pan, it is unclear whether the ritual would be complete by June 2011.
jbgroby is offline
Old 03-11-2011, 11:43 PM   #2674
jbgroby
jbgroby's Avatar
I forgot to add that I mounted the under dash tissse holder, Sissy but kinda kool to have.
jbgroby is offline
Old 03-12-2011, 12:12 AM   #2675
Doug19
evobuilder what is your supension set-up and how much is it lowered looks awesome and just what I am after
Doug19 is offline
Closed Thread
