Old 03-05-2011, 02:06 PM   #1
bc327
Help
Ok, i have an 87 gmc 2500 w/350 tbi. It recently started studdering, shuttering,jerking, how ever you want to work it while driving, it almost feels like a missin the motor, however its not, i have changed the plugs (ac delco) cap,rotor,wires and coil and its still doing it, also the exhaust has a rotten egg smell to it, any suggestions? i am new to the tbi motors
bc327 is offline   Reply With Quote
Old 03-05-2011, 06:10 PM   #2
James McClure
One shot, one kill.
Re: Help
Rotten egg smell is a righ exhaust. (Code 13 usually) The TBI unit itself may be the issue. On top of the unit is the fuel pressure regulator which is known to fail but they usually fail lean. The temp sensor may also be telling the computer the eng is ice cold which richens the mixture. I think thats a code 14 or 15. Then there is the MAP sensor which works in conjunction with the TPS. MAP sensor reads manifold vacuum and the TPS reads throttle position. The MAP failure code is 33. I don't remember the TPS code. Also another thing to look out for is the TBI base gasket, which is the place I would go first. Check that with some carb spray, eng running. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 03-07-2011, 12:13 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Help
choke staying on running to rich?mine would give some black smoke
cat clogged up?
check for good exhaust flo,have someone follow you while warmimg up
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 03-07-2011, 12:32 PM   #4
monte0185
monte0185's Avatar
Re: Help
cat clogged up?
Rotten Egg smell is usually a CAT converter clogged up.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 03-07-2011, 02:58 PM   #5
BusinessProfessor
Re: Help
I'd have to agree with monte!
BusinessProfessor is offline   Reply With Quote
Old 03-07-2011, 06:10 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Help
i agree ... wondering why tho, was it running rich....see any black smoke lately?
cat clogged up? or is the heat riser sticking/staying closed?
check for good exhaust flo,have someone follow you while warmimg up ......can't always see "no flo" from inside
seeing he is in NY he is prob using the choke starting
John
