Old 07-10-2003, 08:31 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I've installed ORDs heavy duty front shackles. They were 1/2" longer than stock so only netted 1/4" lift. They required up-grading to 1/2" bolts from the 7/16" stockers. They slightly turn the diff back which increases caster slightly. With my 2" lift and the shackles I have no binding at the front u-joint. Anything longer than this(1/2") and you'd probably have to install shims to rotate the diff back up. I've heard of people installing 2" longer shackles with 8-12" lift springs with shims to clear some big tires.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
