Old 03-06-2011, 10:49 PM   #1
topher
rim backspacing and to narrow or not to narrow
I am building a 1969 c10 reg cab short box 2wd. I am almost done my frame just installed a scotts hot rod supper slam front end kit and a cpp rear air ride kit. I step notched the frame just behind the cab and boxed it.
now that you know what i have done so far what i am aiming for here is a good street truck i can drive in the summer that will handle decently well and have lots of power to put a smile on my face with. for power it will be getting a gm ls 376/515 crate engine backed up by a t56 6 speed.
I have two questions the first being what backspacing are you guy running on your rims i want 20s all the way around with probably 9x20 in the front and 13x20 in the rear. This truck will lay frame and i will tub out the rear as well as raise the bed floor up for the stepped up frame.
my second question is what rear ends are you guys running i have a guy that can build me one locally and i know i will have to narrow it. I just want to see what you guys are running with your bagged truck and what widths you running.
I have built lots of vehicles but up to this point its been allot of 4x4s this is my first low ridder build i have done any info , tips and pictures you have for me would be great thanks in advance for the help.
topher is offline   Reply With Quote
Old 03-07-2011, 10:50 AM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: rim backspacing and to narrow or not to narrow
Moved to suspension forum so you'll get better, more educated responses.
To go with a 13" wide rear tire as you said you will need to narrow the rear.
On backspacing, every truck will be different and will depend on how you lower it (spindles/dropmember/etc)
If you have more info on your plans for the front and rear that will help
Old 03-07-2011, 12:08 PM   #3
SCOTI
SCOTI's Avatar
13" wide rear wheels does not 'require' narrowing the rear housing. It requires the proper back-spacing.
If you want a 13" wheel w/a deep lip & less back-spacing, then you need to plan on narrowing the housing (or buying a suitable swap housing). If you look around (search the net), an aftermarket 9"/12-bolt g-body rear housing would be a good choice as it's 4" narrower (2" per side) vs. a 6x-69 12-bolt housing. You might be able to find one @ a good price & just whack the existing brackets off & weld on some truck arm brackets. This is what I was searching for (for my RetroRod project) until I came across a built 12-bolt that was the right length, new gears, posi & axles for the price of an aftermarket 9" housing/axle pkg.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-07-2011, 12:31 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
Is it even legal to run 13" rear wheels without a DEEEEEP lip????
Old 03-07-2011, 01:55 PM   #5
chapster
chapster's Avatar
Absolutely not!! Everybody needs deeeep lip wheels....
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler
1968 Chevy c10 shorty Stepper (Patina LS project)
1967 gmc custom Long Box (Farm Truck Project)
chapster is offline   Reply With Quote
Old 03-07-2011, 05:10 PM   #6
SCOTI
SCOTI's Avatar
There are limitations in my book. I absolutely do not like the almost flush look up front & a 6-7" deep lip out back. It does not look good to me. I prefer keep the lip within 2-3" of each other.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-07-2011, 05:45 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
So I am not the only one that the super deep dish bothers? I LOVE wide wheels, but feel that the dish front to back should be comparable.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-07-2011, 05:57 PM   #8
Painter D
Painter D's Avatar
Agreed
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 03-07-2011, 07:22 PM   #9
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Ummm I have 13" wide wheels..I just had my stock rallies cut and widened??? it was cheap and I didn't have to swap axles or shorten them either??? tub yes!!! and I run 15 or 18" wide M/T's all the time
theres pics in my build
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-07-2011, 07:22 PM   #10
SCOTI
SCOTI's Avatar
Originally Posted by Kabwe View Post
If it is legal it shouldn't be.lol
By the way its really not hard to narrow a rearend if you can weld. I narrow them and the only thing I use is a chop saw and a welder. The way I do them you don't even have to take the gears out. There are pics of two rearends I narrowed in my build thread. One is a 8.5 10 bolt and the other is a Ford 8.8. You could narrowed the 10 bolt like I did the Ford 8.8 and just buy new c-clip axles. The way I did the 10 bolt eliminates the c-clips and if I was doing it again I would have just done it the way I did my buddy's Ford 8.8.
Narrowing a rear housing w/the internals installed? How do you determine there was no distortion from the process? How could you determine end to end accurracy of fixture alignment?
Sure.... it's possible to do just like lots of guys weld their differential spider gears for a 'poor-mans' spool. That doesn't mean it's correct. I'd like to learn what your process is.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-07-2011, 08:27 PM   #11
BossHogg69
motor exploder
BossHogg69's Avatar
I'm running 18x12 on a stock width '69 rear. my bs on the rears is 7.5". I followed SCOTI & N2trux philosophy on this, plus I didn't want or have the money to spend on custom, super deep lip wheels AND narrow the rear. As you can see in the pic below, there is plenty of room from the inside wheel to the framerail. I have a stepside bed, and I'll graft in some fleetside tubs to clear the wheels, but nothing has or will be done to the frame or rearend housing. For me, I feel like I have a good match from front to rear as far as the 'look' goes, and then surprise, surprise when you see it from the back with a 335/30 tire tucked up under there.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 03-07-2011, 09:12 PM   #12
daved
hey bosshogg......what brand tires and wheels.,...any pics of the wheels? love the tread!! how tall are the rears compared to the front???
daved is offline   Reply With Quote
Old 03-07-2011, 09:33 PM   #13
BossHogg69
motor exploder
BossHogg69's Avatar
wheels are the Boss 338, kinda like belly buttons around here these days... I have more pics of them on my profile page.
Tires are BFG gforce kdw's, 245/40/18 front, 25.7" tall, 335/30/18 rear, 25.9" tall. I would have liked to run the 275/35's in front, but of course, they came out after I got the 245's...
Too bad no one makes a 335/35 anymore because a 275/40 front and 335/35 rear would be BEAST .
Adam
Old 03-07-2011, 10:01 PM   #14
Hottrucks
Hottrucks's Avatar
do you think the tires are going to fill the wells ok?? they are alot shorter than the stock 29" tires..I fought over that when I was building my truck I wanted wheel/tire combo that would keep things close to stock
on a side note how do you like that Scotts front end....and I look forward to seeing your combo with the body on
Old 03-07-2011, 11:56 PM   #15
SCOTI
SCOTI's Avatar
This does not sound like a question it sounds like a statement. I was just sharing info take it or leave it. I'm not here to debate or convince take my build for what it's worth, if its not worth anything to you that's cool. Its posted for people who find it to be helpful.
I was going to PM this but figured if you took my post wrong, others might have as well. So, I wanted to set the record straight (in public)..... You're right, it was both (question & statement). The question/s portion:
The statement portion:
It appears you were successful so it can be done. I question only if it should be done that way or if there are better, more accurrate methods. I wasn't attacking you or the integrity of your work. If you were offended, I apologize.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-08-2011, 03:23 PM   #16
GhostTown
GhostTown's Avatar
Ugh..... you guys are bad for me. Now I want to tub my truck and go the Bo$$Hogg route.
GhostTown is offline   Reply With Quote
Old 03-08-2011, 04:14 PM   #17
BossHogg69
motor exploder
BossHogg69's Avatar
Is this what you had in mind topher??
don't do what I did, just skip my little bs and go for the throat....
22x14's with the 405 width Pirelli's.
Adam
Old 03-08-2011, 04:17 PM   #18
GhostTown
GhostTown's Avatar
That's a very, deep, dish.........
Old 03-08-2011, 10:17 PM   #19
topher
Thats the exact look i am aiming for bosshogg i might even go with 22s after seeing that pic
Old 03-09-2011, 12:09 AM   #20
BossHogg69
motor exploder
BossHogg69's Avatar
Come to think of it, those rear wheels might be 24's - I don't have the hard copy of it, thanks to a coworker that 'borrowed' that issue from me. You can find it online at www.truckinweb.com, under the 'featured trucks' tab.
Adam
Old 03-11-2011, 10:35 PM   #21
topher
hey bosshogg what is the backspacing and width for the front rims in the first pic you posted ?
Old 03-12-2011, 12:33 AM   #22
BossHogg69
motor exploder
BossHogg69's Avatar
22x8.5, but I don't know the bs on them - but from the looks its a lot, since the wheel face it almost flush with the wheel lip. The rears are 24x14's I did check on that too.
Adam
Old 03-12-2011, 01:46 AM   #23
topher
sorry i was talking about the first pic you posed of just the frame with the 18x12 on the rear with 7.5 backspacing do you know whats on the front of that c10 ?
Old 03-12-2011, 09:54 AM   #24
BossHogg69
motor exploder
BossHogg69's Avatar
Yeah, I hope I know, since that's my truck (frame)
The fronts are 18x8 with 4.5" backspace.
Adam
Old 03-12-2011, 07:56 PM   #25
GVizzle
GVizzle's Avatar
Ken,
I like deep dish pizzas!!!!!!
GVizzle is offline   Reply With Quote
