1969 Custom 30 wrecker
Are cowl panels being repro'd?
I see that fire walls are available but was wondering if the piece just above that is available? This piece goes behind the fenders and runs up across the top. (not the outer cowl that you see but the metal just under that)
Thanks, Bob
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Re: Are cowl panels being repro'd?
Yikes! $249 dollars. Not sure I can justify spending that much but thanks for the link!
$279 for the outer??? They are everywhere used in great condition for 1/10 that much. That piece takes a lot less to make than the inner. Makes me wonder about the quality of the inner.
![]() Join Date: Mar 2000
We have the inner cowl panels available for $195.00ea part#5724081, they can be found on the following page of our web site
http://www.gmcpauls.com/Patch_Panels.htm Heres a couple pictures of this part ![]() ![]() Paul @ GMCPauls |
Here's some pictures of the cowl being changed on my Cheyenne 10. I bought this from LMC and believe it or not, the fit was good for being an aftermarket piece. Couldn't believe my eyes how good it fit.
I got mine from Southern KY Classics www.sokyclassics.com . $195 and it fit great.
"Some of my finest hours have been spent on my back veranda, smoking hemp and observing as far as my eye can see." - Thomas Jefferson 72 C10 SWB "Work in Progress" |
What do you all think a shop would charge to change this cowl panel out? The truck was at the shop, front cap off, then we discovered that the cowl should be changed. This is what was done: 1) Cowl cut off; 2) Sand blasted under cowl; 3) Some pinholes welded under cowl; 4) New cowl installed and primed with epoxy primer. Anybody want to chime in with an estimated cost, not including the cost of the new cowl? Keep in mind this truck is in restoration at a reputable shop because I'm no paint and body or sheetmetal man.
That must be nice, cuz their tailgates sure don't fit worth anything.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy" 1996 Gmc 1500 Z71, 350, 4l60e, 3.73s 1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s 1989 Toyota Pickup 22re, auto, 3.73 |
hey i might be cutting up a 68..it has a good cowl ( has some rust by the vent locations)..ill know in 2 weeks..im getting a different cab,so ill have no use for this on(the roof is in bad shape..
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604) |
#11 | |
