How to figure rear drop?
I was wondering how/if you can accurately guesstimate the amount of drop you will get with a rear flip kit or a homade rear flip for a 73-87 1/2 ton. I read once that you can measure the thickness of your leaf springs and then add 1.5" to that. But to me, I would think you would add 3" to that figure cause you would go off of the axle center line?.
Anyone know how to do this? I made my own perches at work awhile back and would loike to figure out about what rear drop I can expect, so i'll know what exactly i've got to do for the front.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030 ![]() 97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver 220,000 miles, all stock for now |
Happy to be here
![]() Join Date: Mar 2000
Re: How to figure rear drop?
You will get about 5" with the flip. If you run shackles it will give you another 1-2" .
Posted via Mobile Device |
It depends on the thickness of the spring pack because you're flipping the axle from one point below the springs to another point above the springs. A 3"od housing has a tube diameter w/a 1.5" radius. You add the dimension resulting from moving the axle C/L 1.5" from below to above a surface + the dimension of the surface itself.
Some spring packs are 4-leaf; some are 5, & some are 8-leaf/HD set-ups. The more leafs the spring pack has, the greater the overall amount of drop & why the advertised drop of a 'flip-kit' can vary.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-06-2011 at 09:31 PM. |
Ok, I think I got it.
Mine currently has an 8 spring pack on it, thinking about removing a couple of the leafs.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030 ![]() 97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver 220,000 miles, all stock for now Last edited by Conundrum; 03-07-2011 at 07:41 AM. |
8-leaf spring pack w/a flip kit = a full 6" of drop (minimum). Removing leafs will have some effect, but it would be a 'per vehicle' amount of drop because weight & spring rate will vary.
I know that removing leafs doesn't mean i'll gain any more drop, just don't see the point in keeping that many leafs on a lowered truck that will probably never haul much more than a cooler and a spare tire.
