Old 03-07-2011, 01:55 PM   #1
storked82
storked82's Avatar
Need help / dual fans
Hello guys
Yesturday I bought some dual fans at a swap meet my problem is how
Do you wire them together? so they both come on when I hit the toggle switch PICTURES PLZ if you have them
Thank you
Jeff M
storked82 is offline   Reply With Quote
Old 03-07-2011, 06:16 PM   #2
Nolowrider
Nolowrider's Avatar
Re: Need help / dual fans
I wired mine separatley with a relay (75 amp) and a diode for each. I then installed a continious duty cycle solenoid and ran both to that. Dual fans pull a lot of juice on start up.
Nolowrider is offline   Reply With Quote
Old 03-08-2011, 01:56 PM   #3
Rons86
Rons86's Avatar
You can buy a kit at any auto parts store that has averything you need for about $40. I am doing the same thing to my truck.
Rons86 is offline   Reply With Quote
Old 03-08-2011, 02:10 PM   #4
jrcaprai
Yep, a solenoid for each Fan
jrcaprai is offline   Reply With Quote
Old 03-08-2011, 05:23 PM   #5
Clyde65
Clyde65's Avatar
this is what I used, but make sure you use a Maxi-fuse
http://www.oreillyauto.com/site/c/de...1388&ppt=C0331
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-08-2011, 07:10 PM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
I used to run mine in a setup where they both came on at the same time, but that worked my alternator more than I wanted it to. It also made my headlights dim at stoplights. I purchased a dual fan controller from SPAL and then an extra fan relay to support the heavy duty fans. There are other outlets out there that do the same thing.
My fans cycle on one at a time (starting at slow speed and increaing as the heat load is increased) and if the heat load is large enough, then both fans can run to support the load.
Look at the following websites
www.centechwire.com
www.spalusa.com
Frank
Old 03-08-2011, 10:08 PM   #7
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Wire them seperately. Use a fuse for each one. Tie them together only by their relay connections. Use the on wire to fire both relays. Each fan should have its own power and ground. I even have a fusible link wire at the battery connection.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
