![]() Join Date: Mar 2000
The bolt pattern is the same on both 6lugs rims 6 on 5.5"pattern, but hub clearance since its a 4X4 may be to small, also may have a problem if you try to use a original drum brake 6 lug wheel as it may not clear the caliper.
GMCPaul |
