Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-05-2011, 08:26 AM   #1
team39763
Questions about installing rollbar.
I read that the truck needs to be perfectly level. Is that referring to the truck sitting on the ground(all 4 tires) at the desired ride height? Or does it mean up on jackstands and the frame leveled? We're finally about to start on the rollbar and I just want to do it right the first time. My truck used to have the "chevy lean" but I shimmed up the body mounts to make the bodylines match. Now it only has a small .5" difference in fenderwell height from side to side. I don't know if that makes a difference.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 03-05-2011, 11:51 AM   #2
ripdog28
ripdog28's Avatar
Re: Questions about installing rollbar.
Have it on Jack Stands and leveled out. Make sure it is square from corner to corner. Your suspension may sag differently from side to side but you need the cage to be on straight.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 03-09-2011, 12:54 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
X2...make sure the frame is level in all directions.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
