Old 06-08-2010, 04:55 PM   #1
baggedcten
86 C10
baggedcten's Avatar
Another "What's this?" thread
whats is this?
Whats it for?
Where are the wires supposed to be going?
Thanks!
p.s. not my pic found it on this website so thanks for who ever took it
1986 C10
2001 chevy silverado purchased 8-29-09 sold
2004 silverado purchased 8-27-10 sold
baggedcten is offline   Reply With Quote
Old 06-08-2010, 04:59 PM   #2
pcmcobra
pcmcobra's Avatar
Re: Another "What's this?" thread
It's a junction block, feeds power to cab and somewhere else, I forget, ran all new power under my hood, but I am still using that block.
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 03-06-2011, 11:03 PM   #3
bigd65
bigd65's Avatar
This part ( The JUNCTION BOX) on my 82, the small pin has a wire that goes to the blower motor. The one that was on there was evidently burnt and ALL the wires were attached on the one pin. I got one off of a junk truck but no power goes through it from the larger pin(The POWER PIN) to the smaller pin ( The Blower Motor Power). The blower motor does not work now. Is this also a fused link for the the power to the blower motor.
I seen in one picture there is a fuseable link that splits from one wire to two. That is where I was getting very confused, That also feeds the power to the gauges so I think I may be ok on that part now.
NONE of the wire colors in all the diagrams I have found, match my 82 So this is really killing me. I am shopping wrecking yards to see if I can find and un-molested harness that will match mine
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 03-07-2011, 10:16 AM   #4
dropd80s
dropd80s's Avatar
Ties all the main power feeds together. Power from the battery (starter terminal), alt., power to the fuse box to power the cab, and one wire to the passenger side to power the blower motor. They should all have fuseable links.
dropd80s is offline   Reply With Quote
Old 03-07-2011, 10:58 AM   #5
muddnutz
muddnutz's Avatar
How about vacuum switch next to it. What's it for? Mine isn't connected
muddnutz is offline   Reply With Quote
Old 03-07-2011, 11:19 AM   #6
jchav62
1962 C-10
jchav62's Avatar
Looks like it may be the switch for the lock up converter... ?? I could be wrong. Someone's bound to know for sure...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 03-07-2011, 01:09 PM   #7
Toxic Redline
Toxic Redline's Avatar
All i know is if you drop your alternator while the hot is still hooked up and the battery still attached (changing the alternator in harmons parking lot) it will melt that fusable link that is below it
84 K20 Long Box W.I.P
78 Burb - parts now [Rolled]
68 c20 dump bed
WHEN IN DOUBT--- FLOOR IT
Toxic Redline is offline   Reply With Quote
Old 03-09-2011, 10:58 AM   #8
dropd80s
dropd80s's Avatar
Yes its for the converter lock up.
Old 03-09-2011, 11:29 AM   #9
muddnutz
muddnutz's Avatar
Old 03-09-2011, 12:01 PM   #10
lo72
Truck Junkie
lo72's Avatar
Could someone tell me where the vacuum hose goes from the lockup converter switch? PO removed the hose from the switch and i can't find a diagram to know where to reattach to provide vacuum to the switch
lo72 is offline   Reply With Quote
Old 03-09-2011, 01:53 PM   #11
muddnutz
muddnutz's Avatar
I hooked mine back to manifold vacuum port
Old 03-09-2011, 03:46 PM   #12
lo72
Truck Junkie
lo72's Avatar
and it shifts ok? My truck has a 350 turbo now but it came with a 700r4...All of the plugs are there. I wonder how much trouble it would be to put it back?
