Old 03-10-2011, 01:28 AM   #801
VA72C10
VA72C10
VA72C10's Avatar
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
I'm sure that made your wife and neighbors happy to get rid of that
Old 03-10-2011, 01:30 AM   #802
VA72C10
VA72C10
VA72C10's Avatar
Exhaust turned out great so far!
Old 03-10-2011, 08:36 AM   #803
dlturner00
Thumbs up Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
Wow! I just went through this thread last night. What an undertaking! I've thought about attempting this myself with my 69 LWB. I could probably do the work but finding the time and money is my problem. I thought about just swapping my body over to a later model chassis, but I just don't know if I could dedicate myself to the extent you have. I have to say, for someone who doesn't do this for a living, you have a lot of skill. Maybe you should consider a new line of work. I am definitely impressed and I will be keeping up with your project. Thanks for posting all this info. Maybe it will inspire me.
dlturner00 is offline   Reply With Quote
Old 03-10-2011, 10:50 AM   #804
67cheby
67cheby
67cheby's Avatar
i love how everything is tucked in nice between the frame rails ...looks great
67cheby is offline   Reply With Quote
Old 03-10-2011, 11:54 AM   #805
ERASER5
ERASER5's Avatar
That Denali was a boat load!
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-10-2011, 12:20 PM   #806
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Thanks, I have it easy though because the newer frame rails are wider so there is more room in between.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 03-10-2011, 04:29 PM   #807
mgass69
mgass69's Avatar
I have to say, you have quite a project going. I log on everyday just to see what else you've done. Very impressed with your work. It looks factory built. I only hope my 69 C10 project comes out half this good. Keep up the great work!
mgass69 is offline   Reply With Quote
Old 03-10-2011, 06:21 PM   #808
drewskiren
drewskiren's Avatar
My boat trailer never had it so easy.
Drew
Old 03-10-2011, 07:01 PM   #809
Slick67
Sofa King Crazy!!
Slick67's Avatar
This is really a huge, costly undertaking......and you make it look so clean and sanitary?!?!? I love this project and will be around adding views to your thread till it's done.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 03-10-2011, 09:05 PM   #810
thor
thor's Avatar
I just read your entire thread. Awesome! I love reading everything I can on those doing 67-72 crew cab conversions. It is simply amazing! Great job!
I also love the use of a newer drivetrain. I often thought how cool it would be to drop a crew cab conversion onto a newer crew cab too. Nice!
God's Speed!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 03-12-2011, 01:18 AM   #811
monte0185
monte0185's Avatar
Drew,
Just read your entire thread as well. VERY NICE!!! Let me know if you need any help with anything. Be glad to. Glad those cabs were able to be used for something.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 03-13-2011, 08:31 PM   #812
drewskiren
drewskiren's Avatar
Picture Time
I made some progress on the firewall and welded in the giant grommet hole.
I mounted the dummy air handler for the last time and it all works out, so I have them side by side to make the final modifications to the real air handler I am using.
Drew
Old 03-13-2011, 09:56 PM   #813
gcburdic
Restoration Virgin!
gcburdic's Avatar
Gee whiz....I'm glad I caught this one to watch before you are done!!!...Great work here Drew....I appreciate what you and your family do for missionaries and believe it or not, I use to eat those Charles' Chips growing up...loved them....
Keep up the great work....I look forward to seeing you finish this one
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 03-14-2011, 01:08 AM   #814
drewskiren
drewskiren's Avatar
It was such a pretty day that the Lord had made, we worked outside. While I painted the exhaust with Eastwood products, I had the boys sanding down the bed with 120 grit.
Drew
Old 03-14-2011, 01:13 AM   #815
VA72C10
VA72C10
VA72C10's Avatar
Looks good. You'll have to let us know how that paint holds up.
Did you have to do anything special to prep it?
Old 03-14-2011, 01:16 AM   #816
drewskiren
drewskiren's Avatar
I had to order the Eastwood version of Dynamat to insulate the firewall before I do the final install on the Air unit. It is less than half the price of most others. Something I had to do to fit the unit under the dash was move the wiper motor over about 3 inches. I'll fabricate a new arm linkage later. Prepping the firewall with Bondo since I am finished drilling holes and welding up others.
Drew
Old 03-14-2011, 01:20 AM   #817
67chevy1series
67chevy1series's Avatar
wow the bed and cab look nice and clean! great job drew looks good the exhaust looks good to i wonder how long it will stay nice sliver
67chevy1series is offline   Reply With Quote
Old 03-14-2011, 01:23 AM   #818
drewskiren
drewskiren's Avatar
And now for the moment of truth, will she fit????? YES!!!
Tons of clearance for the trans. and fuel lines with the high hump.
Engine has at least an inch on the passenger side, way more on the drivers. Not even close to the firewall. All of the body mounts lined up and frame barely shows under the truck.
Sarah had me put the seat in so she could check it out.
Drew
Old 03-14-2011, 01:29 AM   #819
drewskiren
drewskiren's Avatar
More pics of the non-event...
I'll pull the cab back off again of course for paint, but I have to have it in place to set up the steering and brake booster mount.
Drew
Old 03-14-2011, 01:36 AM   #820
drewskiren
drewskiren's Avatar
Starting to look a little more normal.
A shot of the fresh air intake from the inside.
Drew
Old 03-14-2011, 01:46 AM   #821
VA72C10
VA72C10
VA72C10's Avatar
Awesome! Great job!!!
Old 03-14-2011, 02:05 AM   #822
Dinos63
chevy only
Dinos63's Avatar
wow!!! great job concrats
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 03-14-2011, 05:12 AM   #823
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
COOL COOL COOL! You are an amazing artist for sure! Keep up the good work in and out of the shop!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 03-14-2011, 09:04 AM   #824
Cameron 1137
Cameron 1137's Avatar
Its as if the factory made it! It looks like it fit perfectly.
Cameron 1137 is offline   Reply With Quote
Old 03-14-2011, 09:14 AM   #825
drewskiren
drewskiren's Avatar
I says it is good to 600 degrees, so it should be there for a long time. The manifold paint is good to 1200 degrees and reminds me of powder coat because it never fully dries until it is baked by running the engine.
The metal was so rough already, I just washed it/scrubbed by hand and shot the paint.
Drew
