Old 03-10-2011, 09:09 PM   #1
60ratrod
yes, i do
60ratrod's Avatar
best location for inline electric fuel pump?
this is for my tpi conversion. i know the closer to the tank the better. and fortuneatly i already have the return line stock installed. but i was wondering if its ok to put it in the cab or put it on the frame rail?
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 03-10-2011, 09:26 PM   #2
cparman
sharp as a marble
Re: best location for inline electric fuel pump?
IMO, you need to mount it on the frame rail near the tank. Electric pumps push better than pull. I would also find a way to insulate it ( rubber mount it) to keep the noise down
cparman is offline   Reply With Quote
Old 03-10-2011, 10:00 PM   #3
stich626
in the cab,, if you want to be covered in fuel if a line lets go..
stich626 is offline   Reply With Quote
Old 03-10-2011, 10:13 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You'll want it down low so it also gets the syphoning to help. Frame rail under the cab is the best location.
Old 03-10-2011, 10:49 PM   #5
60ratrod
yes, i do
60ratrod's Avatar
alright. well what i think that i am going to do is remove the feed line and mod it with screw in fittings and flare it so i don't have to run many chunks of rubber hose to connect the pump. at least i don't have to worry about installing the return line since mine has the factory return line
Old 03-11-2011, 12:24 PM   #6
stevencvn72
Kill Bill...et
stevencvn72's Avatar
You might double check the diameter of that return line to be sure it's sufficient for TPI. A problem I ran into was the factory return in a stock '72 sender was way too small and would end up shooting your fuel pressure waaaaay up. Let us know what you come up with!
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 10-05-2011, 01:45 PM   #7
firethorn
Hi stevencvn72
do you have pics and or info of your install of the fuel delivery & return system
thanks
firethorn is offline   Reply With Quote
Old 10-05-2011, 02:17 PM   #8
Crabass
Putting any fuel component in the passenger compartment is a CAPITAL NO-NO!!!!!
Even proper fuel pressure gauges isolate any fuel from the passenger compartment.
Crabass is offline   Reply With Quote
Old 10-05-2011, 02:21 PM   #9
bigdogboxers
bigdogboxers's Avatar
Mounted mine right across from the tranny in the frame rail right where the tranny cross member is located that way it was kinda protected and slightly hidden.
bigdogboxers is offline   Reply With Quote
Old 10-05-2011, 04:03 PM   #10
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i concor frame rail
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 10-05-2011, 08:54 PM   #11
Longhorn Man
Is the fuel tank considered a fuel component?
Old 10-05-2011, 09:34 PM   #12
Ackattack
Ackattack's Avatar
On my 72 with a TPI 350 I mounted the fuel pump on the frame rail and used the stock sending unit as for the supply and return lines with no problems. Just avoid running it below 1/4 tank.
Ackattack is offline   Reply With Quote
Old 10-06-2011, 07:56 AM   #13
Crabass
Heh-heh, holy brainfade, you got me there. Been so long since that butt-bomb was in my truck I forgot about that. Guess I need to get out more.
Way back when my (then) future ex-wife proclaimed that neither she nor her son would get into that truck until the cab was "dry". Hmm, I guess maybe something positive did come out of that disaster, after all.
The factory putting fuel in the cab was bad enough, but the thought of DIYers plumbing gasoline through the cab kinda gives me the willies. A really bad place to have one of those "Bubba" moments.
I think my statement still applies, especially to modifications.
Nice catch, Longhorn!
