Old 03-09-2011, 03:42 AM   #1
83GMCK2500
Need some wiring advice for my '83
I'm going to be relaying the headlights here real soon and I'd like to add a simple relay center underhood. I'm trying to find a 3-4 relay block with associated fuses but I'm coming up dry. Biggest thing is I'd like to make it look as OEM as possible.
Any ideas?
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 03-09-2011, 11:44 AM   #2
dropd80s
dropd80s's Avatar
Re: Need some wiring advice for my '83
You can check summit or painless sites see if they have something that might work for you. If not try the junk yard. I think mid 90s devilles had a 3 or 4 relay bank under the hood. Im sure you can find something that will work.
dropd80s is offline   Reply With Quote
Old 03-10-2011, 10:17 PM   #3
83GMCK2500
I will keep my eyes open, thank you. Devilles...hmmm, would've thought Caddys had a zillion relays.
Devin
New Daily, the '96
Old 03-10-2011, 10:29 PM   #4
one low c10
my 96 s10 had a 4 relay block that mounted on the firewall and the relays "hung" on it... check it out
one low c10 is offline   Reply With Quote
Old 03-11-2011, 12:43 AM   #5
BellyAche Jr.
KC Hilites has fuses, harness, etc... Easy install
BellyAche Jr. is offline   Reply With Quote
