03-10-2011, 02:26 AM | #1 |
Unorthadox Traling Arm Removal
When I decided to replace the trailing arm bushings on my C-10, I planned to remove the arms so I could work on them on my bench. Eveything came off OK till I got to the U-bolts on the axle. My air wrench wouldn't budge them. Tried heating them- no good. Got a breaker bar with long pipe on it- you can see the result below. I didn't have a bolt splitter and I didn't want to cut the u-bolts so I just lowered the axle on a couple of jacks. The inner sleeves and old rubber pressed right out- clean! A little tricky lining everything up but no real trouble. I'm wondering- How many others have done it this way?
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! Last edited by Zonaman; 03-10-2011 at 02:40 AM. |
03-10-2011, 02:45 AM | #2 |
Re: Unorthadox Traling Arm Removal
I had to cut my u bolts and have yet to get the things off
Posted via Mobile Device |
03-10-2011, 02:49 AM | #3 |
Big Red - Now its a SWB!
You can easily remove the u-bolts by using a cut off wheel on an angle grinder. I've snapped off the bolts before when trying to break them free in the junk yard. If I had a grinder that I could use in the junk yard that would have been my first choice, but you gotta make do with what ya got.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
03-10-2011, 03:01 AM | #4 |
Moderator
I had to burn out the old bushings with a torch...they were stuck in there for life. Removing the U-bolts on the trailing arms was easy.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
03-10-2011, 09:39 AM | #5 |
Now keep that wrench under your front seat, it still has uses.
Creative solution by the way! Last edited by ubtripn; 03-10-2011 at 10:05 AM. |
03-10-2011, 10:56 AM | #6 |
You mean like a boomerang?
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! |
03-10-2011, 12:20 PM | #7 |
18 Till I Die
How did you press out the bushings ?
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
03-10-2011, 12:39 PM | #8 |
More like that steering wheel lock convieniently caled, "The club."
03-10-2011, 12:48 PM | #9 |
Old Skool Club
Dang, I feel cheated. Mine came out of the crossmember w/o any issues. The biggest problem was getting the coil spring retainer loose. One galled nut really messed with us, but we didn't let it take us down.
I think it was the fact that we had the rear end out and turned upside down that let us get serious with it..... ....waitin' on the sandblaster to call and say he's done..
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
03-10-2011, 04:43 PM | #10 |
I would just cut the ubolts off. They are cheap and most auto stores should have them.
2007 Chevy 2500HD all stock 1985 Chevy Blazer- sold 1971 Chevy c10- The Mistress 2014 Ford Interceptor SUV |
03-10-2011, 07:56 PM | #11 |
Get some PB Blaster and soak them the day before after wire brushing around the u-bolts and nuts. Soak them again a couple of hours ahead of time. This has worked on all but one of my bolts on my truck. The tailgate pivot bolt on bottom snapped while trying to work back and forth. If that don't work, they probably aint worth saving anyways.
03-10-2011, 08:47 PM | #12 | |
03-10-2011, 09:32 PM | #13 |
sharp as a marble
Looks like you have the nuts off already? I had the same problem on my 69. I put the nuts back on several threads. heated the control arm red hot, and with a BFH drove the ubolts out. Thinking back, I would/should have cut the ubolts off and junked them along with the control arms.
03-10-2011, 11:18 PM | #14 |
I just needed the inner sleeve and the rubber out (polyurethane replacments). I used a 3 jaw puller with a socket over the screw. Insead of pulling it was pushing. It's real dry in Arizona and, as I suspected, that 40 year old rubber wouldn't give me too much trouble. In fact, it came out clean on both bushings. That rubber was dried out like a rasin! I thought I might need to wire brush off some from the sleeve but it was bare metal in there.
If I was going to remove the outter sleeve, I would surely have cut the bolts because there's no decent way to press them out from undneath. I didn't have a car that day but figured I could get it done this way instead of waiting till the next day to go hunting for u-bolts. It worked but I don't think too many folks ever do it that way. What's PB Blaster? Sounds like good stuff.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! Last edited by Zonaman; 03-11-2011 at 11:09 AM. |
03-11-2011, 03:09 AM | #15 |
The Niner
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
03-11-2011, 07:22 AM | #16 |
Watch out for your cornhole !
You can buy PB Blaster at any Walmart or O Reilly.
