Old 03-10-2011, 11:20 PM   #1
gavinmosher
Shake/Shimmy Front right side????
Hey guys i know i kinda chime in with questions periodically and i appreciate all the help lol.... anywho i have a 84 chevy c10 with stock suspension..... it ate up my last front right tire so i got all new tires..... now i noticed it has a really bad shake at about 55 mph..... i dont want it eating up my tire again.... i also noticed that when i hit bumps with the front right side i hear a knocking from the suspension area can anyone give me an idea?
gavinmosher is offline   Reply With Quote
Old 03-10-2011, 11:28 PM   #2
cableguy0
Re: Shake/Shimmy Front right side????
More than likely a ball joint. Put a floor jack under the control arm. Jack the truck up. Grab the wheel top and bottom and try to move it back and forth. Have someone else look to see where the movement is. Its either going to be a wheel bearing or a ball joint but more than likely its a bad ball joint.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 03-11-2011, 08:06 AM   #3
James McClure
One shot, one kill.
Gavin, check the ball joints like Cableguy said, but also take a look at the upper control arm bushings. Any trouble in the front end should be a red flag. Check ALL the linkage connections (tie rod ends, pitman arm, idler arm). If it's got a grease fitting, check it. Also remember sway bar bushings and linkage. Rubber bushings should ALL be replaced if you find one bad. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 03-11-2011, 11:27 AM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
years ago i made the mistake of overtightening the nut on the front wheel bearings. When my car at the time ( 74 duster) got good and hot from running it it messed up the would make a terrible shake on that side.. so make sure your wheel bearings are good and not overtightened
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
