Old 03-12-2011, 07:33 PM   #1
dcody619
59 Diff drain plug size?
Hey guys,
Does anyone know the rear differential drain plug size for a 1959 1/2 ton 235ci truck? It is missing on my project truck and what should i fill it up with? Would it b possible to clean inside?
dcody619 is offline   Reply With Quote
Old 03-13-2011, 01:10 AM   #2
mr48chev
mr48chev's Avatar
Re: 59 Diff drain plug size?
I've got one out here out of a 55/59 truck that's easy to get to but it's too late an too cold tonight.
I think if you look at the threads, they are fine threads and the plug has a sholder on it and takes a gasket.
Ecklers shows this one for a car http://www.classicchevy.com/chevy-re...1957-1964.html and I think the truck uses the same one but can't guarantee it.
Old 03-13-2011, 01:27 AM   #3
dcody619
Thanks! So what do you use for diff fluid?
Old 03-13-2011, 01:33 AM   #4
dcody619
Old 03-13-2011, 09:07 PM   #5
mr48chev
mr48chev's Avatar
I looked a while ago and no drain plug on the rear end I have it has the removable cover.
I run 80/90 weight in mine.
I'm pretty sure that if you can figure out the size and thread you can get a drain plug at the local parts house. Especially if they have a set of Dorman cabinets.
