Old 03-13-2011, 08:52 AM   #1
Lost 40
Lost 40's Avatar
Where does your exhaust exit?
Looking to see pics of what different things people have done with their exhaust on their trucks. Her are two pics to start...
1986 Chevy C10
2" Drop
350 SB
350 Turbo Trans
"Keep it rubber side down, in between the ditches"
Lost 40 is offline   Reply With Quote
Old 03-13-2011, 11:42 AM   #2
DetroitDan
DetroitDan's Avatar
Re: Where does your exhaust exit?
whoa. that is pretty
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop.
DetroitDan is offline   Reply With Quote
Old 03-13-2011, 11:45 AM   #3
CoggedBelt75
CoggedBelt75's Avatar
Before the axle.
Joe
__________________________________________
1975 C10
"Questions are a sign of intelligence indicating a desire to eliminate ignorance"
CoggedBelt75 is offline   Reply With Quote
Old 03-13-2011, 11:51 AM   #4
DetroitDan
DetroitDan's Avatar
For some odd reason, mine has perfectly intact 2.5" exhaust pipes from the manifolds back to the mufflers, which arent leaking but dont look too healthy either. The odd part is, off the back of the mufflers it has tiny pipes that bend up over the rearend then turn 90 degrees and one exits out each side behind the wheels. I don't mind the side exit at all, beats backing them into snowbanks and trailers and so forth, but I cant understand why someone put like 1.75" tailpipes on it. Also, the tailpipes are all rotted through even though they are probably newer. So I guess my answer would be, some of my exhaust exits on each side behind the wheels, but a good portion of it exits under the truck through all the rot holes in the little tailpipes.
Sounds good though. What 454 doesn't?
Old 03-13-2011, 12:06 PM   #5
chevymotocross
chevymotocross's Avatar
Dynomax Super Turbo mufflers dumped under bed before axle. Pipes are close to ground due to the truck being lowered. Wish I never dumped them because at low rpm everything rattles.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 03-13-2011, 12:09 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
stock right under the rear most right corner
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-13-2011, 01:58 PM   #7
Pro Performance
Pro Performance's Avatar
Mine is dumped before the axle with 2-chamber flowmasters.
Pro Performance is offline   Reply With Quote
Old 03-13-2011, 02:08 PM   #8
87 chevy silverado
basically the same as his
87 chevy silverado is offline   Reply With Quote
Old 03-13-2011, 02:27 PM   #9
boatpuller
boatpuller's Avatar
i went old school hot rodder,drop down.it's true dual.you can only see one side in this pic.but,the other is the same.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 03-13-2011, 02:53 PM   #10
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
out the back
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 03-13-2011, 02:59 PM   #11
ChevyC102007
ChevyC102007's Avatar
True 2.5 Duals with glasspacks exiting behind the rear tires
"When you were born, you cried and the world rejoiced.
Live your life so that when you die, the world cries and you rejoice."
[Cherokee saying]
2001 Dodge Ram Sport 1500 4x4. (old ride)
1987 GMC V1500 Sierra Classic ("new" ride)
ChevyC102007 is offline   Reply With Quote
Old 03-13-2011, 03:00 PM   #12
Reziel_1983
Reziel_1983's Avatar
Out the back pretty much like you have yours Lost 40.
Reziel_1983 is offline   Reply With Quote
Old 03-13-2011, 04:11 PM   #13
bbbc10
Diggin The SquareLife
mine
bbbc10 is offline   Reply With Quote
Old 03-13-2011, 04:25 PM   #14
81chevylongbed
got 2 glasspacks into turndown tips dumped under the bed before axle...sounds great! stock manifolds true duals 2" pipe all the way back.
81chevylongbed is offline   Reply With Quote
Old 03-13-2011, 04:39 PM   #15
80chevyshortbox
80chevyshortbox's Avatar
80chevyshortbox is offline   Reply With Quote
Old 03-13-2011, 05:03 PM   #16
3r!c84
Badass
3r!c84's Avatar
got any pics on how it hangs under the gas tank and go's out before the tires?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 03-13-2011, 07:17 PM   #17
bbbc10
mine dnt hang below gas tanks....
Old 03-13-2011, 07:18 PM   #18
bbbc10
bout to get shortys cause bout to get LOW!!!
Old 03-13-2011, 08:04 PM   #19
Lost 40
Lost 40's Avatar
Wow, I love your paint job. That looks to be the same color as my truck. I love the white on yours though, it really breaks up the gold. Looks sharp. I might have to get some info from you on that!
1986 Chevy C10
2" Drop
350 SB
350 Turbo Trans
Old 03-13-2011, 08:58 PM   #20
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Hooked!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 03-13-2011, 09:28 PM   #21
Chlorin8ed
true duals, out the back angled at the corners...
1987 Chevy R10
2004 GMC Sierra
1980 Chevy Malibu
Chlorin8ed is offline   Reply With Quote
Old 03-13-2011, 09:46 PM   #22
80chevyshortbox
i dont have any pics of it on my comp atm. all take pics and upload them monday night if i rember.
Old 03-13-2011, 09:51 PM   #23
Grande Rojo
paper or plastic?
Grande Rojo's Avatar
Grande Rojo is offline   Reply With Quote
Old 03-13-2011, 10:02 PM   #24
donut
donut's Avatar
Mine's like gchemist, but a whole lot uglier. They used to exit behind the wheels, but a snowbank forced me to shorten them up
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 03-13-2011, 10:05 PM   #25
madcow75
madcow75's Avatar
LOST 40 where did you get those outlets coming out of the side of the box. I'd love to purchase pair of them.
madcow75 is offline   Reply With Quote
