Old 03-14-2011, 08:01 AM   #4
tobiahr
tobiahr's Avatar
Re: about camaro engine... for my jimmy
for the reverse flow coolant you need to make sure you have the radiator connected so the flow goes from top to bottom (in on top , out on bottom) and the water pump is what came with the engine (reverse flow). for the electric fan just make sure you get one rated for the engine/radiator size and you should be ok
tobiahr is offline   Reply With Quote
