1970 GMC
07 Wheels on a 70
Need a little help. I would really like to put a set of 07 GMC wheels on my 70 GMC pickup. However the center hole on the 07 is apparently too small. Has anyone done this, and does anyone know of a way to accomplish this?
They are 6 lug wheels.
MadDog's Website |
![]() Join Date: May 2002
Re: 07 Wheels on a 70
haven't done it, but you should be able to have the center hole machined out to the proper size.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
You could use a spacer. just a thought.
1969 C-10 LWB 388 SBC Vortec Heads 10:1 Lunati 60103 cam Weiand intake Quadrajet Carb 12 Bolt 3:73 posi 700r4 Hedman Headers 1998 Dodge Ram 1500 Reg. Cab Long Box 4X4 5.9L 183k miles 1956 Ford F-100 Longbed with Original 272 and 3OTT 1995 C1500 ECSB 6.5 Diesel 4l80e (Camper puller) 1997 Dodge 3/4 ECLB V10 (MPG machine) ![]() |
its all about the +6 inches
if you hog out the hole, then you'll find the back spacing to be way off. At best, it'll look funny, at worst, you won't be able to turn the wheels much up front. (all this depends on what '07 wheels you use)
A spacer is about the only way to make it work right, but they aren't a very good idea in all reality, and if you do go with them do NOT get the cheap ones. You get what you pay for, and a wheel passing you at 70 MPH on the freeway would suck for you and everyone else around. |
1970 GMC
Thanks for the advice guys. I just sold my set for more than i purchased them for, so I guess all is well that ends well. It's too bad though I think they would have looked good.
MadDog's Website |
