#351 |
Re: 55 2nd serie GMC
NICE work on that door man
excellent work are you welding with gmaw?mig?
Smoking Tires Since 1992 1969 c10 AKA SIN 1985 SSWB TRAZER (super short wheel base) |
#352 |
![]() Join Date: Nov 2008
Thanks, i use a cheapy little gasless mig i bought 20 years ago but still works good.
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 Last edited by JML55; 01-31-2011 at 12:24 AM. Reason: spelling |
#353 |
Still working on the body work, here are some pictures. A little boring but i know some of you like to see tons of pics. Pass door skin turned out very nice, I'm fine tuning the gaps and edges shape.
I'm off to Mexico in a couple of weeks for my daughter wedding and a little vacation at the same time. Can't wait to get out of this -40 degrees temperature we've had here lately. So work on the truck will be at a stop for the next little while.
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 |
#354 |
Here is one more thing done or i should say redone. I wanted a better looking grill with a more custom look instead of home build like the one i did first. So a couple months ago i got a machinist to designed the new grill on the computer and make it for me. We made this one out of one piece mirror finish stainless steel. Its laser cut and the holes were punched out with this huge computerize puncher machine. The first pic shows the old and new one side by side.
#355 |
that grill is sweet lookin...
#356 |
#357 |
![]() Join Date: Jun 2010
Great lookin grill, real nice touch.
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
#358 |
#359 |
I'm not tail-gating, I'm drafting. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=432758 |
#360 |
Thanks, yes it turned out much better then that first one i made out of that exhaust shield.
#361 |
The grill looks great.
Kim |
#362 |
The grill is a very nice custom touch, better than factory.
1962 Chevy blue SBFS 1957 Chevy yellow SBSS 1956 GMC red SBSS Nov 2017 ToTM https://www.facebook.com/groups/Cana...geChevyTrucks/ |
#363 |
Impressive workmanship so far.
I'm scribed. Ratty 46 |
#364 |
![]() Join Date: May 2007
Can't wait to see the grill on the truck.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#365 |
A320 Pilot/USAF Retired
Awesome!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#366 |
#367 |
#368 |
More body work this weekend, couldn't really do anything else, we got snow in most of the weekend from this blizzard that started Friday night. I hope this snow stop soon or we will still have snow on the ground in June. Anyway got a little more done on the front fenders, tried to fit the headlight ring, the new set i have don't match the fender at all. The originals do fit well so i may be using the old ones and get them chromed. This after market stuff sure doesn't always fit right. I'm happy with the door gaps and the fitment between the doors and the front fenders so far, will see later when i put the door seal on.
#369 |
Looking good. I'm hoping to start priming mine soon.
Kim |
#370 |
Certified Car Nut
Looking great. Keep it up man you are doing a great job.
#371 |
Thanks, its going slow but its getting there.
#372 |
Looking GREAT! What body filler do you use?
#373 |
Just good quality bondo.
#374 |
Wow i'm still doing body work and i thought it was almost ready for paint. Actualy the last guy that did the paint job said it was ready for paint. Been bloc sanding and working on the gaps for hours. Its taking a lot more time that i thought first. It took quite some time to fit the headlight rings, i have three sets and none of them fit right. I finaly put a coat of primer on the doors and fenders tonight. More bloc sanding to come. I still have to install the new driver side step. I should have that done this weekend.
#375 |
It's really looking slick! I'm sure you are tired of sanding, but the finished results will be worth it, and you can say you did it yourself!!
