Old 03-11-2011, 11:47 PM   #2951
jsmithbm
jsmithbm's Avatar
Re: Project Vitamin C-10
Cant always hog it on there haha..... We're gonna make a painter out of you yet.. At least your shop is not making you body guys prime the stuff you fix like they are down here.
_Truck is looking good as always. Lookin forward to the chewing fat!
Originally Posted by Alan's Classic View Post
Got a little painting done. I didn't put enough hardener in it apparently. Because it was slow to dry. I used the right reducer just got cross-eyed looking at the measuring lines. I brought the parts home just in case I get some time this weekend. I painted the M/C, vent window frames, condensor brackets and front shrouds. The shrounds didn't turn out good, i ran the heck out of one of them. I should have laid them down, but I didn't. (I only painted the top of the shrouds.) Some day I will learn. Maybe.
Learning as I go!
jsmithbm is offline   Reply With Quote
Old 03-13-2011, 11:11 PM   #2952
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Thanks Joel!! Maybe I can be a painter someday.
Crazy weekend, not much time in the shop. I did manage to start my other vent window frame. The second one is always easier. The first time I installed the rigid strip first. That for me was a no-no. The wrap around goes in first as seen below.
Parts laid out on a padded work bench.
With some lube for it to squeeze into the channel I installed the wrap around piece first.
The rigid piece needs to be bowed a little to get it in the corner pockets.
The wrap around didn't fit as well as the first one. It seemed a little short on both ends.
I pulled it back out of the track some to fix the end gaps by shifting it. I trimmed about 1/8" off because it binding on the pivot bracket. It really didn't help much it was just too short.
With everything in and lined up it's ready for the rivets.
I will be posting this in the FAQ Wing/Vent window rebuild.
Alan's Classic is offline   Reply With Quote
Old 03-13-2011, 11:21 PM   #2953
SFTorange
SFTorange's Avatar
Looks good! I like the padded workbench. Even with a detailed thread showing how to do the job, I managed to find a way to mess mine up. I installed the "D" shaped washer that goes in along with the fiber washer on the pivot assembly backwards, and it wouldn't let the window open up. I had to drill out the pivot rivet, take the assembly apart, and turn the washer around. It wasn't a big deal, but I only had two pivot rivets. I'm still waiting for my new one to arrive.
Anyway, like I said before, the FAQ writeup was a big help.
SFTorange is offline   Reply With Quote
Old 03-13-2011, 11:24 PM   #2954
Alan's Classic
Thanks, remember you saying that. I just finished editing the FAQ stating to make sure people pay attention to the orientation of the pivot stop. Thanks for the heads up. I'm going back to the FAQ to edit some more.
Old 03-14-2011, 11:15 AM   #2955
56taskforce
56taskforce's Avatar
This is getting exciting looks like it won’t be long now. Soon to have glass !!!! What you going to do when this is done? Road trip in the truck to Disney Land???
56taskforce is offline   Reply With Quote
Old 03-14-2011, 12:26 PM   #2956
198plus
198plus's Avatar
Great progress and looking good...........
198plus is offline   Reply With Quote
Old 03-14-2011, 08:20 PM   #2957
flips72
flips72's Avatar
i just cant get enough of that dash, man that thing is beautiful, you do some excellent work. cant wait to see it completed.
flips72 is offline   Reply With Quote
Old 03-14-2011, 08:23 PM   #2958
Alan's Classic
Thanks, slowly but surely.
Does anybody have a pic of the ebrake setup with all levers and springs and guides that pull the intermediate cable to the sides. A factory diagram would be great. I did some digging for my old parts. The pics below is what I have found so far. I'm not even sure the spring and long rod are part of the setup. I have to adapt the crossmember brackets over to the CPP trans mount. Undecided on how I really want to do it. I'm waiting on some parts to show up so I can start piecing it all together.
Old 03-14-2011, 09:04 PM   #2959
Alan's Classic
Thanks!! It's a labor of love thing.
Old 03-14-2011, 09:44 PM   #2960
TR65
TR65's Avatar
Hey Alan,
Here is a pic of mine I took so I could remember how it went.
The big spring goes from the very bottom hole in the pic to the rear cross member with a little hook rod that acts as an extension.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 03-14-2011, 09:59 PM   #2961
Alan's Classic
Originally Posted by TR65 View Post
Hey Alan,
TR
Thanks TR, that's funny I was doing a search and found that pic earlier and downloaded it. I couldn't remember who's pic it was. I was going to up load it for comparison, but didn't. Because I forgot. I don't have the link on the upper left of your assy. Maybe it didn't have it. I did find some more things to go along with it. Just have to wait on parts to arrive. I tried searching for factory service manuals. Guess I was doing something wrong.
Old 03-15-2011, 12:30 AM   #2962
Alan's Classic
Spent the night looking for parts, sand blasting some small stuff and finished up the pass vent window. All it needs now is a glass.
Old 03-15-2011, 12:40 PM   #2963
56taskforce
Oh man I can't waitBut where did all thoughs extra parts for the e-brake come fromI would like to help but all my trucks are BIG and the e-brakes are on the drive lines.
Old 03-15-2011, 08:43 PM   #2964
SFTorange
SFTorange's Avatar
Has anyone ever installed the 1966 e-brake setup on one of the earlier trucks? It is much simpler, and doesn't require a crossmember.
Old 03-15-2011, 09:08 PM   #2965
198plus
198plus's Avatar
Do tell.......
Old 03-16-2011, 12:14 AM   #2966
Alan's Classic
You know how extra parts accumilate. Horse trading and I did part one out.
Never heard of anyone do it. Not even familiar with the earlier setup.
Goodies arrived today. I bought a complete firewall grommet kit. I will only be using the speedo and ebrake grommet for now (2 on the left). Not even sure which grommet is for the speedo cable. I think it is the one with the angled hole thru the center.
I probably could have gone to the local parts house for the battery cables, but it is easier to just click it and have it mailed.
I got the vent window installed temporarily. Also installed the front ebrake cable, speedo cable, left door regulator.
Old 03-16-2011, 12:53 AM   #2967
SFTorange
SFTorange's Avatar
When I was shopping for new e-brake cables, I noticed in the catalogs that the 66 trucks use a different setup than the 60-65's. They came up with a new system for '66 that eliminated the complicated bracket/linkage setup and replaced it with a setup that only uses cables and a couple of rods. It is easy to work around when you swap out your stock transmission for an automatic, and it looks like some guys have replaced the earlier crossmember style brake setup with one from a '66. I'm out of town tonight, so I don't have any pics of mine, but I tracked down this page on Woogeroo's site.
http://sites.google.com/site/woogero...1966c10ebrakes
Here is a diagram from the 1966 shop manual that shows how it works.
I hope this helps. It seems like guys spend a lot of time getting their e-brakes to work right when it might be easier to swap out to the '66 style.
Old 03-16-2011, 10:06 AM   #2968
Strodder
Daring to be Different
Strodder's Avatar
Looks like Christmas Allan.
I'm using the 73 e-brake set up, with a foot pedal.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 03-16-2011, 10:06 PM   #2969
Alan's Classic
Thanks for the pic. I remember that style now. I'm still looking for a pic like that for my style ebrake. I don't have a FSM.
I should have preplanned for that.
Filled in the spot welds on one side of the TG and header. I used the tape to keep from making a mess. If filler gets in a crack it is a PITA to sand out. It makes for easy cleanup.
Old 03-16-2011, 10:08 PM   #2970
Strodder
Strodder's Avatar
Nice job Allan.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-17-2011, 11:59 AM   #2971
structures
structures's Avatar
you really pay attention to those details man. Looks great.
Robert
1965 Chevy C10
http://67-72chevytrucks.com/vboard/s...d.php?t=374373
1997 Chevy K2500 6.5 diesel
structures is offline   Reply With Quote
Old 03-17-2011, 05:33 PM   #2972
flips72
flips72's Avatar
like structures said attention to details, that is what will make your truck stand out in a crowd. excellent work.
Old 03-17-2011, 06:43 PM   #2973
Alan's Classic
Nice job Allan.
Thanks guys!! The attention to details are killing me. I'm to the point I want it done. So I have been over looking somethings in the body work. Most people will never ever see or notice. Trying to let go of my OCD.
Primed bed and other parts. Slicking out the inside of the TG wasn't easy. They make a great TG, but to slick it out took a little more wiping than just spot welds. Don't get me wrong I love the TG, but to get it to the next level took a little work. It's not perfect now, I'm letting it slide.
Old 03-17-2011, 08:47 PM   #2974
Strodder
Strodder's Avatar
WOW looks perfect.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-17-2011, 09:15 PM   #2975
awbrown
Smile Re: Project Vitamin C-10
Being a member of this board does two things , One , you get to see just how good other guys on the forum are .. And second it forces me to try new things , in hopes of someday doing work that is better (not ever equal to yours Alan ) .. Tonight I replaced the trans tunnel and shifter in my 63.. The one that was in it was hacked bad , and the one that was replacing it needed a corner replaced .. the hacked one had a good corner ,so I thought I would try to do it right instead of overlapping them like I do most of the time ... after fitting the pieces and welding it all together I thought to myself "Alan must be rubbing off on me" .. Then I reviewed some of your work and came back to real life.....
awbrown is offline   Reply With Quote
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
