![]() Join Date: Feb 2009
Manual Transmission Options?
GUys,
I think I am going 700R4, but I would like to explore transmission options. The truck has the intermediate bell housing rear engine mount, normal clutch setup...Is my only option the T5 chevy S-10? Are these very stong? DOnt I have to punch a new hole in my floorboard for shift tower, since the tower is further back? Are there any threads on this topic? Are there any 4-speeds I should look at, besides the origional granny low version? |
Re: Manual Transmission Options?
Lots of options, depending on how much work you want to do. If I was gonna change out my SM 465 (and I'm not) I would go with a modern 6-speed - but you have to fabricate for the hydraulic clutch and electronic speedo. Do a search, there's a lot of info on this.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
The t-5 is the easiest swap. They are not real strong but if you don't abuse them they will stand up. I run one in my 58 with a 350 & it works great. You do have to make a new hole in the floor.
Big Red - Now its a SWB!
There was a thread on here a while back where the guy used an adapter on his t56 (six speed) that allowed use of the stock bell housing, flywheel, and fork, but he had to change out the clutch disk because of the different spline count. The speedo still has to be sorted out though. I'll see if I can find it.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
Here's the one I was talking about http://67-72chevytrucks.com/vboard/s...t=polished+t56
Collector of Projects
http://www.keislerauto.com/
Did you start a build thread for this truck... I coulnd't find one or any pictures..... ![]() |
![]() Join Date: Oct 2010
NV-4500?
I hear those can be put together. |
The Older Generation
Here is a thread where I posted about the ax15 5 speed trans. http://67-72chevytrucks.com/vboard/s...d.php?t=417079 If you get a trans with the electric speedometer here is a solution for that: http://67-72chevytrucks.com/vboard/s...d.php?t=421745 LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-16-2011 at 11:00 AM. |
