![]() Join Date: Sep 2002
68 rear end swap or conversion
Certifiably crazy person |
![]() Join Date: Jun 2002
Easiest: rearend out of '71-72 chevy truck with coils
Not as easy: rearend out of 73-84 (will require cutting old brackets and welding) Another way: pull the axles and have them redrilled for 5 x 5 bolt pattern (my uncle is a machinist and did this once for me, I also had to buy new drums for the rear) Hope this helps, Roger
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
We can roll all Day!!
Does anyone know if you can get 5 lug axles for these designed to be used in a disc setup? Or if you can get the 5 lug drum axles for the 6 lug rear and get a disc kit for the 5 lug drum axles? Email me if you know dapolice1@ev1.net
