Re: Round hole to Squaer hole.....
Originally Posted by THE "10" SILVERADO
Thanks Frank.....like how noticeable? It won't really bother me much but I'd like to cover it as much as I could (pet peeve I guess) could you be able to cover up the gap with sealer if you were to reseal (closest word I can think of if caulk) the bed as I plan on doing? and 79+ applies to 81-87 right?
I do not think it will cover with caulk . If you trim the old piece from the inside of your old quarter panel you can probably use it to patch the inside of the new panel. You could trim the new panel a bit and either tack weld the old piece in or bolt the old piece in place and caulk it then . We are only talking about a small 1/2 to 1 inch gap here . Not really that much of a difference.
Frank
Born and proudly residing in a Red State !
