Old 03-17-2011, 07:13 PM   #901
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
Musical cabs again. This should be the last time I take it off. I am preparing to paint the firewall and interior this weekend and once that is dry, back on she goes for the last time.
That 4 by 4 has a huge bow in it, I picked it at the Home Depot and got it half price. They thought I was nuts for wanting it at all. It almost goes to flat when I lift the cab with it - perfect!
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 03-17-2011, 08:50 PM   #902
68restomod
68restomod's Avatar
ive gotta say it is quite the impressive build ...but what about the cab corners? maybe i missed a post
68restomod is offline   Reply With Quote
Old 03-17-2011, 09:14 PM   #903
drewskiren
drewskiren's Avatar
I looked back and page 7 shows the first cab corners I installed which were junk, also on page 7 it shows the good ones compared to a second set of bad ones I got off ebay. I am just now getting around to installing them.
Also page 7 shows the gas filler neck mods.
Drew
Old 03-17-2011, 09:49 PM   #904
drewskiren
drewskiren's Avatar
Somethings not right. (first pic)
It was such a beautiful day, we worked outside. I wiped all 4 cuts with a THIN layer of Bondo and got out the air file (in line sander). This is a fantastic time saving tool which really makes body work turn out nice. Unless you only have a tiny spot to fix the orbital sander you probably have is the wrong tool, and will only lead to waves of frustration. The thinner/closer to the final shape you can spread it the less you will have to take off with the sander. Sand it down fairly flat, but don't try for perfection, if you do it will end up too low and need another coat. Any high spots in the metal will show up easy as bare metal, get out your hammer and dolly and tap the high spots down with the dolly behind. You are looking for a real solid sound, you'll know it when the dolly is directly behind your blow. For spots you can't get behind you'll just have to tap/dent it down and fill with Bondo.
Drew
Old 03-17-2011, 10:12 PM   #905
drewskiren
drewskiren's Avatar
Cab is now back on the rolling cart and in the final stages of sanding in preparation for painting the fire wall and interior. I love my rolling cart - so handy.
Drew
Old 03-17-2011, 11:36 PM   #906
67chevy1series
67chevy1series's Avatar
looks awsome drew, glad you do sopmthin every day you will have this thing done in no time of you keep at it like you are!
67chevy1series is offline   Reply With Quote
Old 03-17-2011, 11:51 PM   #907
VA72C10
VA72C10
VA72C10's Avatar
Nice progress. Today was a great day here for weather and progress
With how fast you're going....you might as well put that fourth door in before you jamb the cab
Old 03-18-2011, 09:59 AM   #908
drewskiren
drewskiren's Avatar
I think I might, I've got all day tomorrow.
NOT !!!
Drew
Old 03-18-2011, 12:43 PM   #909
drewskiren
drewskiren's Avatar
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
Just a side bar on Dynamat. I found it installed on my donor truck, and it really is amazing how well it deadens the interior. On a newer model truck though, it probably doesn't add that much since they are so well insulated from the factory. On our trucks, I am sure the difference will be nothing short of amazing.
Since I was too cheap to buy the name brand Dynamat, I was worried my Eastwood Brand would be only a poor copy and not as good or effective. I was very pleasantly surprised when I compared the two and realized the Eastwood brand was actually thicker. I'll assume with sound deadening material that thicker is better, right? And it is about half price of the name brand stuff!!!
Drew
Old 03-18-2011, 12:46 PM   #910
67cheby
67cheby
67cheby's Avatar
have you ever decided what to do on your headliner ??
67cheby is offline   Reply With Quote
Old 03-18-2011, 12:57 PM   #911
VA72C10
VA72C10
VA72C10's Avatar
Thicker isn't always better on the soundproofing...the dynamat is the extreme version. It's meant for use just like you see where it forms easily to all the contours of the door. The thicker material has a problem bending to those contours or at least sticking over time....which once it's loose from the panel it loses most or all of its' effectiveness.
That being said the eastwood stuff looks thin enough to form and will be leaps and bounds over a cab without it!
Old 03-18-2011, 01:00 PM   #912
drewskiren
drewskiren's Avatar
Nope. Got any bright ideas. I'm open.
Drew
Old 03-18-2011, 01:07 PM   #913
drewskiren
drewskiren's Avatar
Aha. Yes it is thicker, but not by much. Good thing our old trucks don't have complex stampings like new trucks. I have a 1 inch wide and a 2.5 inch wide J roller to press it down really well. I can't wait- oh I have to, darn.
Drew
Old 03-18-2011, 10:51 PM   #914
drewskiren
drewskiren's Avatar
Worked a little tonight and got the other cab corner on. I need to finish putting any heat on the cab so I won't mess up my interior paint.
Drew
Old 03-18-2011, 11:01 PM   #915
mcbassin
Still Learning
mcbassin's Avatar
Nice work as always Drew keep it up!
Old 03-18-2011, 11:28 PM   #916
VA72C10
VA72C10
VA72C10's Avatar
Looks good!
Old 03-19-2011, 04:35 PM   #917
drewskiren
drewskiren's Avatar
Craigslist is the best!
2 days ago I posted an ad that I had a black console I wanted to trade for a flip seat console. Today a guy showed up and we swapped even. I couldn't be happier and neither could he! While he was here I also sold him $70 of worthless plastic interior parts that were cracked or scratched on his truck that I would have ended up throwing in the trash. Nice.
Drew
Old 03-19-2011, 09:03 PM   #918
VA72C10
VA72C10
VA72C10's Avatar
cool deal!
Old 03-19-2011, 09:14 PM   #919
drewskiren
drewskiren's Avatar
Weak Picture Time.
I spent most of the day doing prep work and you would never know.
I did manage to get a fair bit of seam sealer in my hair.
Later, I put my old tag in the back window so I could drive around.
Drew
Old 03-19-2011, 09:22 PM   #920
VA72C10
VA72C10
VA72C10's Avatar
do you need a smog test to drive on that rolling cart?
Old 03-19-2011, 10:51 PM   #921
463
463's Avatar
Drew: congrats on your great build (in progress). as i watch your build unfold i just have to ask as you have enough time to sleep but now you have found extra time that you could drive around too? your just the best Drew. best wishes and keep the faith.
Trueman
463 is offline   Reply With Quote
Old 03-20-2011, 08:00 PM   #922
drewskiren
drewskiren's Avatar
Setting up the "booth," getting ready for some paint.
Drew
Old 03-20-2011, 08:15 PM   #923
drewskiren
drewskiren's Avatar
Cab is painted!
Drew
Old 03-20-2011, 08:39 PM   #924
ThreeQtr
Let's see it then..er.. now!
ThreeQtr is offline   Reply With Quote
Old 03-20-2011, 08:47 PM   #925
Pop's C-10
Pop's C-10's Avatar
So tha whole HVAC system is contained in tha cab & there is nothing on tha outter fire wall like a stock system?... That has me thinking...
Pop's C-10 is offline   Reply With Quote
