Old 03-15-2011, 02:55 PM   #1
cstm68
cstm68's Avatar
shaving gas filler
im looking for the pre formed piece for metal to shave the gas filler on the cab, anyone know ware i can get this?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 03-15-2011, 02:57 PM   #2
1low
Re: shaving gas filler
LMC has them cheap
1low is offline   Reply With Quote
Old 03-17-2011, 10:11 AM   #3
thepunisher
thepunisher's Avatar
Intanti has both the gas cap filler and the bed filler parts.
www.infantimachine.com/index.html
Blayne
thepunisher is offline   Reply With Quote
Old 03-17-2011, 02:04 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Good link to make a favorite....
Member Nr. 2770
Old 03-17-2011, 07:13 PM   #5
trkfrk
trkfrk's Avatar
Infanti is what I used. fit like a glove..
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 03-17-2011, 08:50 PM   #6
brad_man_72
the boat guy
brad_man_72's Avatar
I'm lazy, I made mine. Took like 20 min. Cut a piece of steel a little too large shaped it using a hammer on top of a 2x4. As I got the shape closer I trimmed the piece to fit. Then had a friend do the finish bodywork.
brad_man_72 is offline   Reply With Quote
Old 03-17-2011, 09:18 PM   #7
crazy longhorn
Fabricate till you "puke"
Im not lazy, but I am cheep! there is not 1 damn pc on the last pic that you cant build yourself After you did it , & the next dude asks(he!! yes, I DIDIT!) crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-17-2011, 10:29 PM   #8
Zoomin
Man of Mini-Talents
Zoomin's Avatar
A fine piece of garage art!
V
Zoomin is offline   Reply With Quote
Old 03-18-2011, 01:33 AM   #9
Infanti
Infanti's Avatar
I have them in stock.If there is anything i can help you with let me know.
Gerry
Infanti is offline   Reply With Quote
Old 03-18-2011, 07:39 AM   #10
Andy4639
Old member
Andy4639's Avatar
Talking Re: shaving gas filler
I didn't use anything and I payed to have it done. I'm not a body man so it's worth the extra money to have someone that knows what they are doing to do it!
The body guy made the filler peice himself I guess.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-18-2011, 01:20 PM   #11
OJ1988
Just a car guy
OJ1988's Avatar
I got one on the way from infiniti! Ordered off ebay.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
