Restoring a 68 SWB
Wood Floor Modification - Hidden Bolts
I was noticing how my wood bed bolts to the frame and came up with a way to keep from having those bolts come all the way through the wood. With the way that I have done it the bolts will now be hidden.
I bought six 1/2 inch x 2 1/2 inch grade 8 bolts, washers, nuts, and locknuts. I centered the bolts in the crossmember holes and tightened them down with a nut on each side. ![]() ![]() Then I welded both sides of the nut to the underside of the crossmember ![]() You can see here how the bolt will tighten down all the crossmembers from underneath. Not sure if anyone has done this already. Just thought I would share. ![]() Posted via Mobile Device
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
![]() Join Date: Aug 2004
Re: Wood Floor Modification - Hidden Bolts
yep, thats how I did mine, but I didnt weld them. I too didnt want them through the wood.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Restoring a 68 SWB
I guess in hindsight I didn't have to weld them. I could of just used a smaller length bolt and slid it through the bottom support of the crossmember. Then just use another nut and washer on the bottom side of frame mount to tighten it down. Duh!
Tags |
hidden bolts, wood floor |
