Old 03-18-2011, 08:17 PM   #1
Eldubya
Eagle Alloy 225's, 20". Do I need an offset?
Hey all, so on monday I'm going to bite the bullet and finally order these rims. Now I've already asked the backspacing question, and was told to go with a 5" on the front rims (20x8.5) and a 5.5" on the rear (20x10) now that part was easy but I'm not sure if I need an offset either? everything is stock on the truck (79 SWB Scottsdale) but in the future I will upgrade to disc brakes on the rear. Also I plan on doing a 3/5 drop on the truck as well. Thanks for the help, this just happens to be one of those items on the truck which makes me super nervous as i don't want to order them and they not fit when they get here.
As for tires I've been recommended to go with the 255/40-20's on the front and the 295/40-20 on the rear. Think that'll work with everything???
Thanks!
Eldubya is offline   Reply With Quote
Old 03-18-2011, 11:36 PM   #2
SCOTI
SCOTI's Avatar
Re: Eagle Alloy 225's, 20". Do I need an offset?
Thanks!
Backspacing & offset are different terms for the same thing. They both describe the dimensions of the wheels outer edge where the tire seats vs. the mounting pad for the hub.
An 8" wheel w/4.5" back-spacing is the same thing as an 8" wheel w/zero offset.
I used 8" front wheels w/5-5.25" back-spacing. The 5" keeps you off the a-arm lip more. The 10" rear wheel would be pretty close to the inner tub wall @ 5.5" back-spacing. It will fit but you'd have more clearance & still fit w/5.0 back-spacing.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-18-2011, 11:51 PM   #3
justpball
justpball's Avatar
I went with 20x10s on all 4s and with the 5.5 BS
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 03-19-2011, 02:20 AM   #4
BIG KRIS
BIG KRIS's Avatar
Dude that is one nice burb you have if you havent heard it before.
Flowershop Hip Hop & Street Rods
Dropmember
83 Custom Deluxe Almond on Almond
85 Silverado White on Red/Now Chevy LeMans Blue
Rendering in Truckin magazine vol 36 no. 11,2010
BIG KRIS is offline   Reply With Quote
Old 03-19-2011, 05:13 AM   #5
DREAMER1
DREAMER1's Avatar
How's ur turn radius? Does it rub much?
DREAMER1 is offline   Reply With Quote
Old 03-19-2011, 09:32 AM   #6
justpball
justpball's Avatar
its bagged, i can turn it almost full turn aired out, i have some 1in shorter a-arms i am going to put on so i can turn full all the way down.
87 Crew SWB
Build for the crew
90 burb 2wd
Old 03-19-2011, 06:08 PM   #7
Eldubya
wow that is one nice burb, and pretty much re-affirms my choice of rims hehe, So realistically I should stick with the 5" back spacing on front and rear then for ease of fit? or stick with the 5.5 in the rear as justpball doesn't seem to rub in the rear.
thanks!
Old 03-19-2011, 07:16 PM   #8
justpball
justpball's Avatar
I am even running spacers just on the rear to push them out some
87 Crew SWB
Build for the crew
90 burb 2wd
Old 03-20-2011, 12:09 AM   #9
coater
How in the world can you run 10" all around? I was going to do 5" front and 6" in rear,can you do 10" on the front?
coater is offline   Reply With Quote
Old 03-20-2011, 09:30 AM   #10
SCOTI
SCOTI's Avatar
thanks!
Running spacers = less back spacing. This is why I suggested the 5"BS over the 5.5BS for the rear.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-20-2011, 02:27 PM   #11
Eldubya
Thanks for the help, going to order the wheels tomorrow with 5" backspacing on all of them. Seems like that will be the best fit with some clearance.
Thanks again
Old 03-20-2011, 02:52 PM   #12
justpball
justpball's Avatar
you will need 5.5 in the front
87 Crew SWB
Build for the crew
90 burb 2wd
Old 03-20-2011, 05:34 PM   #13
SCOTI
SCOTI's Avatar
I had 20x8.5" Coys w/5.25"BS on my 74 & they cleared the front fender lips w/o ever contacting. 5"BS would have worked on mine as well & would have required less trimming on the a-arm lip thus why I suggested it.
I haven't looked up the Eagle 225's so I'm not sure what BS options are even possible but anything between 5-5.75" would work. Anything less than 5" & you really have to watch the outer fender lip on >4" front drops. Anything more than 5.75" will start bumping stuff closer to the inside wall of the wheel well.
Pics of my 74 w/the Coys (20x8.5" w/5.25"BS) & one of N2billets 'Lucy' w/some Vintecs (20x8.5" w/5.75"BS). Both trucks had 255/40-20 Toyo Proxes up front.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-20-2011, 07:27 PM   #14
Eldubya
2259-2012 20x10 Polished 5 on 4.5 +2 mm 5.500 3260-09 2100 lbs. lbs.
2259-2015 20x10 Polished 5 on 115mm +8 mm 5.75 3260-09 2100 lbs. lbs.
2259-2028 20x10 Polished 5 on 4.5 +14 mm 6.000 3260-09 2100 lbs. lbs.
2259-2029 20x10 Polished 5 on 4.5 +40 mm 7.00 3260-09 2100 lbs. lbs.
2259-2050 20x10 Polished 5 on 5 +2 mm 5.500 3260-09 2100 lbs. lbs.
2259-2059 20x10 Polished 5 on 135mm +2 mm 5.500 3260-09 2100 lbs. lbs.
2259-2080 20x10 Polished 5 on 4.75 +2 mm 5.500 3260-09 2100 lbs. lbs.
2259-2081 20x10 Polished 5 on 4.75 +14 mm 6.000 3260-09 2100 lbs. lbs.
2259-2085 20x10 Polished 5 on 5 +14 mm 6.000 3260-09 2100 lbs. lbs.
2259-2812 20x8.5 Polished 5 on 4.5 -5 mm 4.5 3260-09 2100 lbs. lbs.
2259-2815 20x8.5 Polished 5 on 115mm +8 mm 5.000 3260-09 2100 lbs. lbs.
2259-2821 20x8.5 Polished 5 on 120mm +33 mm 6.00 3260-09 2100 lbs. lbs.
2259-2828 20x8.5 Polished 5 on 4.5 +8 mm 5.000 3260-09 2100 lbs. lbs.
2259-2829 20x8.5 Polished 5 on 4.5 +21 mm 5.500 3260-09 2100 lbs. lbs.
2259-2850 20x8.5 Polished 5 on 5 -5 mm 4.5 3260-09 2100 lbs. lbs.
2259-2878 20x8.5 Polished 5 on 4.75 -5 mm 4.5 3260-09 2100 lbs. lbs.
2259-2885 20x8.5 Polished 5 on 5 +8 mm 5.000 3260-09 2100 lbs. lbs.
Ok thats what's available from aewheel, so I guess that settles it hehe, 5.5 rear, and 5 in the front
Old 03-21-2011, 01:33 AM   #15
Puglia10
good info here, a common question
1979 c30 3+3 dually
1946 GMC
Puglia10 is offline   Reply With Quote
