Old 03-19-2011, 10:41 AM   #1
jbgroby
jbgroby's Avatar
Getting ready to start wiring
OK, I'm at the point where I need to mount the new E-Z Wiring Harness Fuse block. I know it will go on the front firewall in the upper left section. Since I've never wired a vehicle before I'l need pleant of pointers.
The kit I have is the E-Z Wiring 21 circuit and Dolphin Gauges.
http://ezwiring.com/wiring_harness.html
18 FUSES 21 CIRCUIT
Radio, Coil, Dome Light, Backup/Cruise, Horn, Cigarette Lighter, Fuel Pump, AC/Heat, Radio, Turn Signal, Horn, ACC, Wiper, Gauges, Hazard, Fan, Power Window, Power Door Locks, Brake, Headlights.
I know I will have a few extra wires that will not be used like power door locks, fuel pump, etc. and expect to have to bundle these and tuck them under the dash. Any ideas along those line would be good to know.
What scares me is that I'd like to learn some proper tech about termination connections and the such. I' have Jolly's information on running relays (which I will do for brighter headlights) and the proper way to use connectors and I've read Alan Horvath's tips (he's got to do it all over again becasue painter really messed him up) . BUT there is nothing quite like trying all this new stuff for yourself.
Anybody who has done this please chime in. I'm the type of person who will read something several times before trying just to make sure I have it right (less screwups that way.)
Jake Groby
jbgroby is offline   Reply With Quote
Old 03-19-2011, 10:13 PM   #2
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: Getting ready to start wiring
I would offer some help, but I haven't done mine yet. What I can do is move this thread to the electrical section. Maybe you will receive more answers there. LMK
Alan's Classic is offline   Reply With Quote
Old 03-19-2011, 10:38 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Are you doing a stock rewire or a new updated version? I think the factory routing was strange, but it mite have had to do with the assembly.
Regardless, I would start with the routing of the harness and eliminate anything not being used right off. Just do a section at a time and then figure out your connections.
What are you planning to use for connections? Original style, weather pack, or just crimp style sleeves?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-19-2011, 10:55 PM   #4
jbgroby
jbgroby's Avatar
I don't really know how to correctly answer your question. I suppose I have to follow "stock"? ideas?
Old 03-20-2011, 12:11 AM   #5
protrash64
protrash64's Avatar
For me, I thought it was silly that the harness goes to the passenger side for the engine when it's been much easier to run everything out right above the gas pedal. Of course my trucks have HEI and one wire alternators. I also refuse to jump anything off the starter terminal as I find it difficult to access and it can get overheated/melted easily.
Again, my trucks are also all V8. Maybe the sixers are different. If you are restoring, then I would assume you would be using a stock routing path.
I just pulled out a harness I picked up on C/L and started sorting it out. It may go in my 'burb and I'm thinking of using weather packs to do all the connections. It will not be stock!
Old 03-21-2011, 03:27 AM   #6
sahnobi
i used the same wiring harness in my 63 its a very easy setup i just cut the wires that i wasnt using and left about a foot just in case i got a hair up my ass to do some more **** in my truck the good thing about that setup is everything is marked so all u gotta do is read the wiring and attach it to where it is supposed to go
sahnobi is offline   Reply With Quote
Old 03-21-2011, 09:00 AM   #7
Corts60
Just here to tinker
Corts60's Avatar
Hey Jake, as long as you have solid connections and use quality terminals and heat shrink, I think you'll be fine. I know some guys prefer to solder wires and never use butt splices and the like and then just heat shrink over the solder joint.
I am sure I'm not just speaking for myself when I say we wouldn't mind seeing some more pictures of that beautiful cab, so take some pics along the way, will ya?
Old 03-21-2011, 09:30 AM   #8
jbgroby
jbgroby's Avatar
I've set up an album showing all the reassembly process - Enjoy.
http://rides.webshots.com/album/579894970vydbSl
Jake
Old 03-21-2011, 10:06 AM   #9
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I agree with Protrash ... as far as the output to engine compartment.
If you remember my the 'rock-a-billy', I actually ran the harness out the grommet, and thru the fender well to help 'hide' the harness, but this is not neccesary.
I recommend running everything to there locations, following cleaner routes than stock, waiting till the end to tie strap. (as you might add something or change your mind)
One step at a time ... it is really easier than it looks !!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 03-21-2011, 11:13 AM   #10
Clyde65
Clyde65's Avatar
Break it down into sections, route everything, then terminate only those sections your comfy with the routing and that are secure. This worked best for me, course I am a very simple minded guy, and I can only think of......what were we talking about again?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
