Old 03-19-2011, 06:19 PM   #1
jaybyrd66
jaybyrd66's Avatar
lowering question
hey guys, got a couple questions for ya. got a 66 1/2 ton 2wd that im wanting to lower a couple inches. just gonna do a quick cheap job on it. im thinkin bout just cutting the front coils. any idea how many coils i would have to chop off for about 3 inches of drop? and for the rear i have been told that i can just use 3 inch drop blocks, will those work right in these trucks? thanks for any help
jaybyrd66 is offline   Reply With Quote
Old 03-19-2011, 07:00 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: lowering question
Drop blocks can be inserted after taking apart and replacing the rear U-bolts. Usually come in as a kit.
I believe the general rule is 1'' per loop. I cut a set of 1'' drop srings 1 coil and ended up roughly 2'' down. You may want to start with one coil and see how you end up. All springs are different and no telling what mite happen on old springs.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-20-2011, 02:08 AM   #3
kalirodding
CLASSIX Truck Club
kalirodding's Avatar
If your looking for cheap, Do this. Pull the front coils out and cut 1 1/2 from the front. The rear you can pull out also and cut 2 coils. The back can be done as easy as taking out the top bolt, raising the frame and cutting the coils while still in the truck. Not the best way but it works.
kalirodding is offline   Reply With Quote
Old 03-20-2011, 12:45 PM   #4
astrochimp
Standard blocks will not work (unless you have leaf springs).
There is a thread on how to make them. Hard part is longer U bolts. IIRC it was posted by TX Firefighter.
Rear springs are pigtailed at each end, so "I" would not cut.
Thread is in the FAQ's
http://67-72chevytrucks.com/vboard/s...d.php?t=196457
astrochimp is offline   Reply With Quote
Old 03-20-2011, 08:26 PM   #5
jaybyrd66
jaybyrd66's Avatar
thanks for the replies everybody. and thank you very much for the link astro, it really helped me out
Old 03-20-2011, 08:39 PM   #6
LILJP's66
I cut out 2 full coils in the front of my 66 and removed the rears completely. However I live in Cali and the roads are bumpy as hell here so it rides a lil rough but looks cool. Also my frame sits abut 5 inches off the ground and speed bumps are a pain.
LILJP's66 is offline   Reply With Quote
Old 03-21-2011, 12:08 AM   #7
jaybyrd66
jaybyrd66's Avatar
so no springs at all in the rear? is it just sitting on the bump stops now?
Old 03-21-2011, 12:17 AM   #8
LILJP's66
yes thats right. I am in the process of bagging the truck so this just a quick fix to lowering the truck.
here is a not so clear pic
Old 03-21-2011, 12:25 AM   #9
jaybyrd66
jaybyrd66's Avatar
hmmm, may be worth a try just to see how i like it. not like i cant just put the springs back in if i dont like it. i had thought about doing that before but wasnt real sure how good it would work. and it doesnt have to ride like a cadilac or anything. i rarely drive the old truck. plus if it rode that good then it wouldnt feel like a truck anymore lol
Old 03-21-2011, 12:32 AM   #10
LILJP's66
I only drive this truck on the weekends but the looks I get make up for the gut bustin. It actually feels like driving in a truck that's lifted 8+ inches with 40" superswampers.
Old 03-21-2011, 08:01 AM   #11
Scot_Douglas
Scot_Douglas's Avatar
Many people have gone with stock 97- 02(?) Jeep TJ (wrangler) rear coils to swap out the stock rear coils in the rear end. IIRC, gives a 3" drop and much better ride than the bumpstops.
Check your local 4x4 websites - many have gotten theirs from $free to $20 for a pair.
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 03-21-2011, 08:55 PM   #12
jaybyrd66
jaybyrd66's Avatar
hey LILJP when you dropped your truck that far did you have to replace the tracking arm with an adjustable one or are you still using the stock one with no problems?
Old 03-21-2011, 10:32 PM   #13
LILJP's66
Everything is stock with no problems. I am running 15" stock rims with remington g78x15 tires. I cant feel any pulling nor have I seen any camber wear.
Old 03-22-2011, 12:01 AM   #14
jaybyrd66
jaybyrd66's Avatar
thanks man, i really appreciate it. i think i may just go that route with it then. im like you, not really worried bout how it rides as long as it looks good while its jarring the teeth out of my head.
Old 03-22-2011, 12:04 AM   #15
LILJP's66
no problem. Let me know it you got anymore ?s
Old 03-22-2011, 12:12 AM   #16
jaybyrd66
jaybyrd66's Avatar
will do man, and thanks again. I hope to get started on it tomorrow. ill try to post some pics of it as soon as i can.
If you cant shoot it, Race it, Sleep with it or eat it. down here in Tennessee we just don't need it.
Old 03-22-2011, 12:17 AM   #17
LILJP's66
I'll try to get some pics up in the next day or two. Its been raining and my whitewalls hate the rain
Old 03-23-2011, 03:00 PM   #18
jaybyrd66
jaybyrd66's Avatar
well i got the front lowered today, cut 2 coils off and she is sitting on the bump stops now, will work on the back end this weekend hopefully. here is a couple before and after shots
before
Name:  before lowering.jpg
after
Old 03-23-2011, 04:01 PM   #19
Corts60
Just here to tinker
Corts60's Avatar
Those springs do work great for the pick-ups, but the suburbans are too heavy, as I have just found out, and it will ride on the bump stops with them installed. I wanna say Grumpy had them installed on his pick up and hey worked for fine and could even carry light loads.
Old 03-23-2011, 05:33 PM   #20
likaroc13
Rollin' Old Skool
i had a 5/8 drop on my old '93 C-1500 short/step...it had spindles/springs up front & flip kit, drop shackles, & c-notch in the rear...the front rode great, but with the rear that low i used to dread the crappy Mississippi roads...i can't imagine riding with no springs, lol....hope Tennessee roads don't jar your teeth too much
btw, the front looks great
Old 03-23-2011, 05:34 PM   #21
Slow Build
Slow Build's Avatar
Time out.
In your original thread you said you wanted to lower the back of your truck 3". If you take the springs out (something that I would never even consider) you’re dropping more like 7-8". I’m sorry but I don’t agree with LILJP’s66 on this one. Personally I think it would be dangerous and most likely illegal to run with no rear springs. If you hit big enough of a bump it’s going to lift off the bump stops and slam back down. On bumpy turns the rear-end will try to skip out on you. It’s cool being low but you got to be safe.
I would take the advice of some of the replies above and try the Jeep TJ springs. There's lots of info on lowering your truck on this site including some on the TJ spings. Do some searching and reading.
My truck has had the springs cut (not the best thing to do). I’m going to re-do the suspension (at the same stance) with the use of springs, spindles and blocks.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 03-23-2011, 06:02 PM   #22
kalirodding
CLASSIX Truck Club
[QUOTE=jaybyrd66;4572475]well i got the front lowered today, cut 2 coils off and she is sitting on the bump stops now, will work on the back end this weekend hopefully. here is a couple before and after shots
You have to take the bump stop out. And with a sawzall, cut the bracket that holds it in place. It will give you like 3"s of more clearance. I did that to a few trucks, and worked just fine. NEVER did it bottom out. Unless you go off road or something.
Old 03-23-2011, 07:24 PM   #23
jaybyrd66
jaybyrd66's Avatar
Originally Posted by Slow Build View Post
Time out.
so you cut your rear springs? how much did you cut off them? ive decided not to take them out completely. just wandering how low i can go by cutting them.
Old 03-23-2011, 07:42 PM   #24
Slow Build
Slow Build's Avatar
It was done by the PO. He didn't say how much he took off, but he did say he re-pigtailed them. It's a liveable ride but I'm going to upgrade.
Past GM Trucks:
Old 03-23-2011, 11:10 PM   #25
LILJP's66
I haven't had any bad experience as of yet and I think the pan-hard bar would stop the rear end from sliding. My frame is fastened to the lower arms so it doesn't jump up when I hit bumps. Hopefully I will be putting bags in shortly.
