Old 01-23-2011, 06:15 PM   #1
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
Duallys on 17-19" wheels
im thinking about getting some alloy wheels for mine but i dont like the low profile i want some sidewall but i also think the stock 16" is too small and theres too much sidewall action
Pics!!!
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 01-23-2011, 09:38 PM   #2
SCOTI
SCOTI's Avatar
Re: Duallys on 17-19" wheels
I've been looking for interchangability on wheels myself.
The new model GM & Dodge dually trucks have 17" steelies from the factory. I have a buddy w/a yard that says he can get the newer wheels if I want to trade my current 16" Alcolas. I just haven't found much info on what it would take to swap them.... Nothing? Hubcentric adapters?
I just don't like wheels that have to be polished & I'm not interested in 22's. I wish they did 20" dually wheels.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-23-2011, 09:41 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Scot,
I'd like a set of 16" Alcoas for my truck. Keep me in mind.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-23-2011, 09:44 PM   #4
SCOTI
SCOTI's Avatar
Originally Posted by Tx Firefighter View Post
Scot,
Will do. Any ideas on what it might take to get the newer 17" steel wheels to fit? Most google info is about swapping 19.5's or 22.5's (or larger).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-28-2011, 09:07 PM   #5
cochino12
It followed me home?
cochino12's Avatar
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 03-21-2011, 12:06 AM   #6
Junkpyl
I bolted a set of late model 17" Dodge dually wheels up to my 72 C30 with no issues. 9/16 studs fit perfect and the nuts with the flat flange hold'em on.
Junkpyl is offline   Reply With Quote
Old 03-21-2011, 12:20 AM   #7
SCOTI
SCOTI's Avatar
Good to hear. The Dodge 17" wheels seem to be an easier score when searching for dually steelies.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-21-2011, 04:17 AM   #8
jitteryguy
GoatLube Experss
jitteryguy's Avatar
Pics!!!
if your not gonna lower it, go with the 22.5's and a standard tire, a heavy truck tire on a dually would last longer than the truck will and would look cool too !
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 03-21-2011, 09:24 AM   #9
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
From my understanding 2000 ++ Chevy/GMC will not fit (I could be wrong)
as i was interested in the new 5 star rims on the new duallys.
Some dodge rims will fit years (i'm not sure)
go on Dually Sene and P/M Trevor from Tennese wheel and tire.
here is his site:http://www.tnwheelandtire.com/
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 03-21-2011, 10:28 AM   #10
SCOTI
SCOTI's Avatar
Thanks. I'm familiar w/them.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-21-2011, 10:40 AM   #11
dropd80s
dropd80s's Avatar
I don't think they'll fit with out a lift. The smallest 19.5" tire you can get is around 32" tall, and 22.5s are quite a bit bigger, as you can see.
dropd80s is offline   Reply With Quote
Old 03-21-2011, 01:30 PM   #12
jitteryguy
GoatLube Experss
jitteryguy's Avatar
yes, they are much taller. he has made mention of lift'n or mabey convert'n to 4X4. just try'n to push him along sence I cant talk him to lower'n it.
'85 1/2 ton CCSB
'92 S10 350/350
Old 03-21-2011, 05:20 PM   #13
502ss
502ss's Avatar
Pics!!!
How much side wall are you looking for?
I have also been doing some research on tire options. I plan to go with a 19" (19.5 milled down) but also don't want a 26.71 tire height. What I have found is that I think I am going to go with a 245/55-19 which will give me a 29.61 tire height. I can then run a 235/75-16 tire on the inside rear. If I go with this combo I will be turning 3500rpm @ 75mph with a 4.10. This is only 200 rpm's more than my stock tire height. If I choose to change my gears to 3.53 then I would be looking at 3000rpm at the same speed.
1984 CC Dually - 454 - TH400 - Western Hauler Edition
Big plans are coming!
My build thread HERE
502ss is offline   Reply With Quote
Old 01-10-2026, 12:07 PM   #14
68panelman
68panelman's Avatar
I know this is an old thread, Do you have any pictures?, currently looking to do this on my 72 C-30 and have a good deal on a set of ram 17" dually wheels. I heard the hub size is too big for the 72, thanks
68panelman is offline   Reply With Quote
Old 01-10-2026, 01:34 PM   #15
maxx442a1
He hasn't been on here since 2016 so you probably won't get a reply.
maxx442a1 is online now   Reply With Quote
Old 01-10-2026, 11:11 PM   #16
68panelman
68panelman's Avatar
Had a feeling, but you never know. Maybe someone else has done this swap
