Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-29-2010, 05:56 PM   #1
cooter472
cooter472's Avatar
drag racing rear suspension
I'm new here, I really like to see I'm not the only one racing there big hunk of steel. My question is what type of rear suspension set ups are you guys running. I have a 71 C10 LWB/455 Buick bored and stroked to a 472 CID 3.73 gears. I can stomp it from forty and blow the tires off and from a dead stop use you can guess what happens from there.
Awsume Site
cooter472 is offline   Reply With Quote
Old 12-29-2010, 06:19 PM   #2
vincentgkirkland
vincentgkirkland's Avatar
Re: drag racing rear suspension
stock rear trailing arms ,anti-roll bar, and some use coilover shocks, basic stock rear setup. slicks is the first thing i would do 28x10.5 with your set up,and lose the front sway bar, this just gets things started for you, the track is the only place you can start the tuning process. vince
72 SUPER10
vincentgkirkland is offline   Reply With Quote
Old 12-29-2010, 07:56 PM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
Ditto, street tires are never gonna stick with that kind of torque. Even the Drag radials and slicks will have a hard time hooking on the street.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 12-30-2010, 01:21 AM   #4
vin63
It's Better With Nitro
vin63's Avatar
Kudos for running a Buick...as you can see from my signature, I'm a little partial to the BOPs (Buick, Olds and Pontiacs). As the others mentioned, going to a slick will help at the track. You can probably get away with investing in a set of adjustable rear drag shocks. And, if you can, try making small adjustments to the pinion angle. Start by going down by one degree increments to see if you are able to reduce your 60-foot times.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-30-2010, 09:24 AM   #5
cooter472
cooter472's Avatar
What do you guys think about the tube style trailing arms and cross members offered by the aftermarket, are they worth the money or just weld up the existing ones.
Old 12-30-2010, 11:39 AM   #6
Ont67shortbox
I welded up my existing ones then braced them top and bottom with 1/8x 1 1/2 flat bar,installed new bushings in the front of the trailing arms and use Rancho adjustable shocks in the back, my best 60 is 1.64 but i am still tuning.Save your money on the tube style ones and buy a good set of slicks
Ont67shortbox is offline   Reply With Quote
Old 12-30-2010, 03:03 PM   #7
kpeztruck
kpeztruck's Avatar
I use the stock trailing arms with coil-overs and an anti-roll bar. I did not use stock bushings though. I use a mon-ball from Stock Car Products if I am not mistaken. Had to modify the opening in te trailing arm, and weld the mon-ball housing in the arm. 1.34 60' times for mine. Paul
kpeztruck is offline   Reply With Quote
Old 12-31-2010, 09:59 AM   #8
cooter472
cooter472's Avatar
Thanks for all of the great input, studied alot of performance catologs last night. Wife asked what I was up to, she hates my truck which makes it that much better.
Old 01-01-2011, 04:21 PM   #9
regan wilson
regan wilson's Avatar
Originally Posted by cooter472 View Post
thanks for all of the great input, studied alot of performance catologs last night. Wife asked what i was up to, she hates my truck which makes it that much better.
lmao !
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
Old 01-02-2011, 10:58 AM   #10
djracer
djracer's Avatar
I'm glad i'm not the only one.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-15-2011, 09:05 PM   #11
low&slow
Why lose the front sway bar? What does that do for the truck?
low&slow is offline   Reply With Quote
Old 03-15-2011, 09:40 PM   #12
djracer
djracer's Avatar
It allows the truck to transfer weight better.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-15-2011, 10:49 PM   #13
low&slow
Ah I see. So if you take it out, do you have to add anything to the truck? Or can you just take it out and be done?
Old 03-16-2011, 07:30 AM   #14
djracer
djracer's Avatar
If you don't drive it on the street much just take it off. If you drive it primarily on the street just unhook one side from the lower control arm when you go to the track.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-16-2011, 06:54 PM   #15
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: drag racing rear suspension
Awsume Site
Cool info here:
http://www.competitionengineering.co...s/chassis2.asp
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 03-16-2011, 09:32 PM   #16
low&slow
Yeah it's just a strip truck. Will Not be driven on the street. Is it just 2 bolts to get it off or what?
Old 03-16-2011, 10:26 PM   #17
djracer
djracer's Avatar
4 bolts hold the bar to the frame then 2 bolts or links to the lower control arms.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-18-2011, 12:00 PM   #18
nxtruck
nxtruck's Avatar
Originally Posted by regan wilson View Post
lmao !
x2 !!!!
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 03-21-2011, 12:29 PM   #19
Wasted Income
Boosted Member
Wasted Income's Avatar
Tires are first and foremost, as the stock suspension is pretty darn good as it sits. I used to be able to light my 295/50/15 Radial TAs on the street at 60mph+
Let me just say that Mickey Thomson drag radials are a gift from the heavens. My trailing arms are reinforced with plate steel, and the rubber bushings are replaced with derlin bushings. My truck dead hooks at the track on 275/60/15 M/T DRs.....on air ride.
Good luck and nice work representing those of us with flying bricks
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
