Old 03-17-2011, 11:34 AM   #1
8uwav6
68 Brake Booster Repalce
What all has to be removed to get access to the bolts holding on the brake booster??
I have the seat out, for other reasons, and removed the parking brake lever. There still is very little access to one bolts, can barely see another and have yet to see the last two. HELP
69 CK needing work
86 Buick Grand National
85 Buick Regal Turbo
98 Buick Regal GS Supercharged
06 Chevy 3500 Duramax
8uwav6 is offline   Reply With Quote
Old 03-17-2011, 12:43 PM   #2
dmack91
dmack91's Avatar
Re: 68 Brake Booster Repalce
I believe they are welded to a bracket from the inside. If you are just removing/replacing the booster assembly, all you have to do is remove the nuts from the engine compartment side and remove the booster. The bolts are fixed in place, so no wrench is required from the inside.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 03-18-2011, 01:29 PM   #3
8uwav6
Anybody else have any ideas what has to be removed to remove the brake booster?
69 CK needing work
Old 03-18-2011, 02:00 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
perhaps this thread will help.
http://67-72chevytrucks.com/vboard/s...d.php?t=353088
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-18-2011, 03:51 PM   #5
8uwav6
Crap. Looks like I am going to have a problem then. My booster is directly mounted to firewall.
69 CK needing work
Old 03-21-2011, 11:04 AM   #6
8uwav6
Any help at all?
69 CK needing work
Old 03-21-2011, 11:31 AM   #7
StingRay
StingRay's Avatar
Tough to say as that does not look stock.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 03-21-2011, 12:22 PM   #8
stsalvage
Scrapper 1
stsalvage's Avatar
Smile Re: 68 Brake Booster Repalce
Well We have a problem that is not a 1968 Firewall or a 1967 that is a 1960--66 fire wall or a 1973 and above Cus i can't see the main connector for the front light harness or thye engine harness No it would have to be a 1955--66 chevy truck I have a 1965 3/4 ton all i did was took a 1967--72 brake booster off of another truck with bracket there are two bolts that are already there take just the bracket off the booster or leave it on so you can use a magic marker to put a dot where you need to drill your two remaining holes
It seems like we have a dummy in the mist that Bolted the booster to the fire wall and it really makes things very hard to stop the truck See there is a Leaver between the booster and the Wall there are 2 rods the booster has NB#1 and the pedal Rod is nb#2 one bolts to thetop and that one is from the booster the lower one is from the pedal Best off for you to do is you need to go look at a 1969 -- 1972 chevy trucks the power brake option was a major Option in 1968 cus i have a 1968 Long horn with a 396 400 trans with AC and power steering But NO power brake So best that i can say you need to find any one with a 1967--72 chevy truck that has the power booster
you have one dangerous truck on your hands and all i can say is your brakes mean everything to you and your freedom Manslaughter is a nasty charge when you modify your truck and what ever state you live in Be very Careful
sorry to be extreme about it but you run over a Kid your life is OVER
stsalvage is offline   Reply With Quote
Old 03-21-2011, 12:45 PM   #9
stsalvage
Scrapper 1
stsalvage's Avatar
Just looked on my 1968 all 4 bolt holes are there all you need to do it Find a truck or go on eBay I saw the whole set up for 250.00 it comes with booster Proportioning Valve Bracket lever master cylinder and its for the front Drum rear 11 inch drum in the rear Copy this and put it in the eBay search window and type this > 1967 - 1972 CHEVY / GMC TRUCK POWER BRAKE BOOSTER KIT
Now if you have updated to front disc brakes all you hove got to do is change Proportioning Valve to a disc front drum Rear
Item condition: New
4 available
Price: US $229.00 Buy It Now
7 day exchange | Read return policy details
Shipping: $25.00 Standard Shipping
Estimated delivery within 3-7 business days.
FOR - 1967 - 1972 CHEVY / GMC PICK-UP C-10 & C-20
ZINK POWER BRAKE BOOSTER KIT
FOR DRUM FRONT / DRUM REAR
***SALE PRICE WILL NOT LAST LONG***
THIS COMPLETE KIT INCLUDES
11" Zink Single Diaphragm Power Brake Booster
Master Cylinder With 1 1/8" Bore
PV4 Brass Proportioning Valve Kit with Bracket and Lines
Zink Booster Bracket With Rod Assembly Just For The 67-72 GM Truck
____________________________________________________
PLEASE MAKE SURE THIS IS WHAT YOU WANT BEFORE YOU BUY IT!
IF YOU ARE NOT SURE THIS IS WHAT YOU NEED
PLEASE CALL US TOLL FREE AND WE WILL HELP
1-877-704-6876
ORDER DETAILS
We offer a 2% discount on this item when you pay by phone with your VISA, MASTER CARD or DISCOVER, at (208-324-5763 or toll free in the US 1-877-704-6876, paypal orders are also welcome. Shipping cost listed is to the lower 48 states, anywhere else will cost more, please ask for a quote before you "Buy-it-Now." Please feel free to contact us with any questions.
Our store hours are
Monday - Friday 9am - 6pm MST
If you have any questions about this auction or others please let us know at 208-324-5763.
Thank you for viewing our auction and your interest in our parts and accessories.
We usually ship within 1 - 2 business days of receiving completed & cleared payment
CHECK HANDLING TIME FOR THIS ITEM
Check out my other items!
Please Leave Feedback Accordingly
And We Will Do The Same.
